Wix 57035
by AirgunSavant
05/01/16 12:31 PM
TBN for Oil Change
by Gene K
05/01/16 12:21 PM
Why Even Stop?
by AirgunSavant
05/01/16 12:21 PM
Pirelli Cinturato Strada
by 3for3
05/01/16 12:14 PM
Oiled air filters better?
by paulri
05/01/16 12:08 PM
Transmission fluid change gone wrong!! Help
by Sixxer
05/01/16 12:03 PM
K&N HP-1002 & Fram PH3614
by Recalculating
05/01/16 11:22 AM
Long hauls = go full synthetic?
by Run
05/01/16 11:02 AM
Napa conventional oil $2.19/qt
by slacktide_bitog
05/01/16 10:56 AM
Fiesta ST 5W30
by Pepsibottle1
05/01/16 10:48 AM
More destruction ahead?
by andrewg
05/01/16 10:17 AM
Sticky intake valves
by Ozzmosis
05/01/16 10:11 AM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
94 registered (3for3, AandPDan, 2002 Maxima SE, 2cool, 2015_PSD, 8 invisible), 2021 Guests and 313 Spiders online.
57758 Members
66 Forums
248302 Topics
Page 2 of 2 < 1 2
#3362481 - 05/05/14 02:18 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
glxpassat Offline
Loc: Huntsville, AL
My '03 passat requires a 75w-90, around 14 cst. MTL is a 70w-80. The engines that sit transverse do use the thin gear oil in the tranny.
Edited by glxpassat (05/05/14 02:20 PM)
#3362516 - 05/05/14 02:51 PM Re: VW Passat- Amsoil does not make a gear lube [Re: glxpassat]
badtlc Offline
Loc: KC
They spec 75w-90. They do not use 75W-90. This has been gone over thousands of times. Check the UOA/VOAS of the VW/Audi fluids. They are nowhere near 75W-90.
Fuchs 75W FE is rebottled as the OEM fluid unless something has changed again.
2007 Ford Escape XLS 2.3L ATX, Trop Artic 5W30, MC Fl910s, 135k+
2015 Chrysler T&C, 40k+
#3362552 - 05/05/14 03:24 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
glxpassat Offline
Loc: Huntsville, AL
I had a voa done of the G052-911 which is correct for my car that I bought at the dealer and it was 14.5 cst. There are quite a few different VW G052-XXX fluids.
My VOA
Edited by glxpassat (05/05/14 03:37 PM)
#3362579 - 05/05/14 03:44 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
glxpassat Offline
Loc: Huntsville, AL
Volkswagen Gear Oil Specifications - http://www.oilspecifications.org/volkswagen.php
VW G 052 911
Audi specification for transmissions used with longitudinal engine configurations. Products meeting this specification are of SAE 75W90 viscosity and also meet API GL-5 criteria.
#3363140 - 05/06/14 08:18 AM Re: VW Passat- Amsoil does not make a gear lube [Re: glxpassat]
badtlc Offline
Loc: KC
VW G 052 911
Look up the fluids that meet that spec:
http://www.fuchs-europe.com/products/lubricants-motors-machinery/gear-oils/gear-oils-passenger0.html
http://www.eurol.com/en/37-products/3129-eurol-mtf-75w-80-gl5.html
http://news.blauparts.com/20140505-prerelease-vw-gearbox-oil-g-052-911-a2
As you can see, VW/Audi will say 75W-90 in the user manual and other places but their actual performance specs for the fluids are much thinner. This seems to be typical for all modern VW/Audis out there. Thicker fluids from all the major euro fluid makers (75W90) do not meet the VW spec.
Edited by badtlc (05/06/14 08:19 AM)
#3363341 - 05/06/14 12:24 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
DuckRyder Offline
Loc: Atlanta
Originally Posted By: smokey422
We have a 2014 VW Passat that I love with the 5 speed manual shift and although Amsoil makes an approved motor oil, they don't have an approved gear lube. ....
As a point of order.
Amsoil may make an oil they "recommend" for it or say is "suitable", however there is no Amsoil product listed on the Official VAG Approved Engine Oils .
I would encourage one to understand the distinction.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
  • 2012 Volkswagen Jetta TDi
#3363369 - 05/06/14 12:57 PM Re: VW Passat- Amsoil does not make a gear lube [Re: DuckRyder]
OVERKILL Offline
Loc: Ontario, Canada
Just an FYI but AMSOIL has actually started to pursue the official Euro approvals. Their mid-SAPS product, AFL for example, sports the following OEM approvals:
BMW Longlife-04
MB-Approval 229.51
Porsche A40
I would expect an official VW approval to be coming up, though as noted, it does not carry one currently. smile
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3363548 - 05/06/14 04:11 PM Re: VW Passat- Amsoil does not make a gear lube [Re: OVERKILL]
DuckRyder Offline
Loc: Atlanta
BMW Longlife-04
MB-Approval 229.51
Porsche A40
I actually consider that good news... Looking forward to the update...
Robert
  • 1972 Ford F100
#3363619 - 05/06/14 05:21 PM Re: VW Passat- Amsoil does not make a gear lube [Re: badtlc]
glxpassat Offline
Loc: Huntsville, AL
"Recommendations" and "suitable for" is not the same as meeting spec or having VW approval. You have to believe their claim that it will work. Good luck with that if your tranny dies under warranty.
All I know is my voa of VW fluid shows the fluid is thick. The Ravenol does not meet GL-5 so I don't know how they can make the claim of meeting spec.
Edited by glxpassat (05/06/14 05:23 PM)
#3366327 - 05/09/14 08:05 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
gregoron Offline
Loc: Hawaii
We have a 2014 VW Passat that I love with the 5 speed manual shift and although Amsoil makes an approved motor oil, they don't have an approved gear lube. I like Amsoil gear lubes ever since the first change I put in my 1983 Ford Ranger 4 speed manual pickup. Does anyone know if Amsoil plans on making a gear lube for my Passat?
I'd just stick with the factory recommended VAG manual transmission fluid. I wouldn't call it gear lube as that's for a different application. I've tried RL MT90 on my 2000 Jetta and I liked the OEM MTF better. I'll be switching to it next year.
2014 VW Jetta GLI, 6MT, 16k miles.
M1 0W-40, 8k mile OCI
1995 MB E320, 4AT, 221k miles.
M1 0W-40 (next OCI)
#3373304 - 05/16/14 01:28 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
benjy Offline
Loc: pa
i use Amsoil oils but Redline gear lubes. put MT-90 in my O2J VW 5 speed, it helped shifting a lot. it took about a thousand miles though, wonder why. put it in mt TT's O2M i believe 6 spd manual as well
#3376294 - 05/20/14 09:21 AM Re: VW Passat- Amsoil does not make a gear lube [Re: badtlc]
simple_simon Offline
Loc: Indianapolis, IN
Redline MTL would have been the appropriate fluid, not MT90.
Not if the motor sits longitudinal and uses a spiral bevel gear in the transmission.
Audi/VW use very thin OEM MTF. Usually under 7 cSt at 100C. Redline MTL is much closer to that than MT90.
Then RP Synchromax should be the choice. Same as BMWs. Much better than anything offered by Redline or Amsoil in that category.
#3412891 - 07/02/14 08:11 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
benjy Offline
Loc: pa
many years ago in my 01 jetta O2J 5 speed i had run Amsoil series 2000 in my gearbox-transaxle, after several thousand miles shifting deteriorated, switched to MT-90 + forever happy. using it in my 01 TT 6 speed now, more satisfaction again. i do use Amsoil's REAL synthetic oils though
Edited by benjy (07/02/14 08:12 PM)
Page 2 of 2 < 1 2
