Originally Posted By: Garak
Originally Posted By: A_Harman
But the slightly wilder flat tappet cam makes me want to recommend high-zddp oils, which do not exist in modern full-synthetic 30-weights.
They do if one wishes to look hard enough. There is VR1 synthetic, RP HPS, and Red Line. That's ignoring the most expensive boutiques and dedicated race oils.
VR1 synthetic only has 1000 ppm-worth of zddp in the 30-weights.
RP HPS has 1800 ppm, IIRC. I think there is a VOA on it. I'm not an RP oil fan, but many people here like their oils with the Synerlec additive, which is in HPS. But that is not the RP you see everyday in AutoZone.
And of course RedLine street oils; they have 1200 ppm, so would be good. But I was trying to avoid boutique recommendations in my post. It seemed like the OP wanted readily available oils.
