Need to replace at least the impeller on a '96 Yamaha T50TLRU 50hp outdrive. Have found yammy and aftermarket part numbers. Has anybody used a brand from Sierra Marine? Worth the cost savings over OEM?
Also, not sure whether I need to replace the housing itself or not. Looks pretty good but there is some possible deformation of splines or channels in the passage the driveshaft runs through- never seen one before this so I don't know what it should look like it.
