Thought about this for just a couple of days on whether to switch from castrol gtx 10w30 to maxlife.
I knew where else better to ask an opinionated question but here.
The Tacoma has 149,000+, I've been using castrol gtx 10w30 but since the mileage and I have had great luck with max life in my Cherokee I thought why not start using max life in the truck.
My question is should I stick with 10w30 or switch back down to 5w30 since that's what Toyota recommends since that is labeled on the oil filler cap.
My Cherokee has no problems with it and I just haven't switched for the Toyota.
Cost for maxlife at Wally World is usually under $20 for a 5qt jug anyhow. Just an FYI.
149k+ miles should I stick with 10w30 or drop down to 5w30?
Thanks.
Thanks.
