I posted a used oil analysis here on bitog about a year ago, and the TBN was 2. That was for GC after two years (24 months) of use and 8K miles. Someone commented that I should have also had the oil analyzed for its TAN number. And that the TAN stood for total acid number.
Now with 13 months on this oil change we have about 5.5 K miles on this fill of GC so we are chocking up miles a little faster than we did on the last OC. Therefore 8 K might happen before 24 months this time, and I would like to know if it is worth it to get a more expensive oil analysed by Blackstone instead of the $14 NAPA analysis that does not include TAN. And I do understand that the TAN might be an additional charge.
I understand that TBN is the PH of the oil and it should be on the base side indicating that the oil still has some ability to absorb acid. I also understand that a TBN of 1 is considered the minimum base number and that a TBN below 1 indicated that the oil no longer has the ability to properly neutralize acids. The oil I sent in to have analyzed had a TBN of 2 so it was approaching a TBN of 1 and was therefore a good time to change.
Someone posted that if I really wanted to know if the oil was still good that I should have had the TAN measured, and that TAN stands for total acid number.
What is TAN (total acid number) and how is it different than the TBN number. The PH of the oil is the same regardless of what it is, or what it called, so why or how does TAN differ from TBN and why is it worth paying extra to get the TAN report? What can you tell from a TAN report that you can not tell from a TBN report? And what is the minimum good number for TAN and in what direction on the scale is TAN very good, and TAN bad (such as TBN of 2 is better than TBN of 1) (TBN is better if it is higher).
I am just trying to figure out what the TAN tells about a used oil, and why it would be worth paying for.
Thanks in advance for any information regarding this.
