Originally Posted By: Spetz
I know it'll be a fairly tedious job for me seeing as I have 24 of them to change and the rear bank will be hard to get to.
Though seeing as I don't need the car I can take my time and can do a cylinder a day or even less.
I replaced my rocker cover gaskets some 10,000 miles ago, will they be ok to reuse?
The cost for OEM seals is only about $4, so no reason to go aftermarket (unless they are better)
Tedious? No kidding! That's why you should allow two days in case.
Don't forget to get a magnetic pickup. It's much easier to deal with the valve keepers with a magnetic pickup and it will reduce the chances of dropping them into the engine.
I always replace the valve-cover gasket when I open the valve cover. The only exception is if something goes wrong and I need to do it twice in a row. However, it's probably OK if it's only been 10,000 miles. Aftermarket valve-cover gaskets are usually of very high quality and Fel-Pro brand here is only $15 for the whole set including washers and semicircle plug.
