Beginners guide to external ATF filters?
by buck91
08/29/16 11:27 PM
Good ADBV filter?
by asand1
08/29/16 11:18 PM
my brigs hates synthetic
by meborder
08/29/16 10:39 PM
Butcher factory cooler lines?
by buck91
08/29/16 09:47 PM
Grease for marine davit crane
by davebe
08/29/16 09:10 PM
2016 Traverse, which oil would you use?
by chevman4life
08/29/16 09:08 PM
acclimating to heat - tips, please
by pandus13
08/29/16 08:53 PM
95 Ford Ranger - Runs rough, no power
by dsmith41
08/29/16 08:49 PM
False teeth
by Eddie
08/29/16 08:49 PM
Quaker State engine warranty...thoughts?
by ryan2022
08/29/16 08:46 PM
Hicks Oil
by yankees1
08/29/16 08:32 PM
Looking For A Good Battery For 2011 Santa Fe 3.5V6
by crazyoildude
08/29/16 08:18 PM
davebe, Logos, alphanumeric, koidragon1980, iliveonnitro
58961 Registered Users
49 registered (01rangerxl, akela, 69GTX, albertdi, 4WD, 5 invisible), 1275 Guests and 7 Spiders online.
58961 Members
66 Forums
253753 Topics
#3368578 - 05/11/14 02:02 PM Can MotorGuards run FULLFLOW for Transmission?
canadiantim Offline
Loc: Alberta, Canada
Have several of Ralph's converted MotorGuard Filters sitting around. These are the engine oil style with the external restrictor.
I have been wanting to add at least one of these to our 2004 Ford F-150 5.4l Auto transmission since we tow with the truck.
The cooler lines on the truck are slightly smaller than 3/8" so I'm debating installing 2 Motorguards in parallel without restrictors and running them as full flow in the cooler lines.
I know with the original 1/64" MotorGuard restrictor, I was measuring 1 quart per minute of engine oil through these filters at IDLE so without restrictors these units should flow lots of fluid.
So, other than eventually flow testing 2 of these in parallel, anyone have any thoughts or experience trying this?
Thanks
#3369062 - 05/11/14 11:39 PM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
morris Offline
Loc: ks, wichita
some auto transmissions use the cooled fluid going into the trans is used to lube the bearings. so my idea that restricting flow into the trans is NOT a good idea. i dont know if ford trans is like that, but my chrysler trans is. a good factory service manual should tell you what you need to know
#3369066 - 05/11/14 11:48 PM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
handyman Offline
Loc: TX
You don't need to use two of them. Gary Allen (RIP) suggested running one in parallel with the transmission hoses. That way there is no restricted flow.
2011 Prius III 60k
2006 Senna LE 160k
2001 Saturn L140 160k
1993 Corolla LE 150k
#3369070 - 05/11/14 11:59 PM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
handyman Offline
Loc: TX
2011 Prius III 60k
2006 Senna LE 160k
#3369621 - 05/12/14 04:40 PM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
canadiantim Offline
Thanks. I have them installed on our other cars in parallel to the cooler circuit like Gary suggests but since I have 3 spare complete units, I thought I'd just run them as full flow. I'm trying to maximize fluid capacity as well since it's a towing application.
This Ford truck has a factory thermostat between the trans and the coolers that maintains trans temps about 155F and it is viscosity based so I don't think a slight restriction in a cooler line would cause me any grief as there is always an open route back to the transmission.
I have enough Motorguards that I should be able to filter well with minimal restriction I think? I'm going to have to do some flow testing I think.
I have a factory service manual so good idea to have a look but not sure if the fluid path will be that obvious?
#3372866 - 05/15/14 09:43 PM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
handyman Offline
Loc: TX
Give Ralph Wood a call and talk with him about it. He loves to talk about bypass filters. His phone # is 940 442 9857
2011 Prius III 60k
2006 Senna LE 160k
#3372982 - 05/16/14 02:48 AM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
CDX825 Offline
Loc: Litchfield, Ohio
Anyone talked to Ralph lately?
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Ford F150 5.8 4x4 Rotella T5 10W30
#3373806 - 05/17/14 12:50 AM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
handyman Offline
Loc: TX
I talked with him about three months ago. He's still kicking. He's like the rest of us -- getting older.
2011 Prius III 60k
2006 Senna LE 160k
#3375092 - 05/18/14 08:06 PM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
canadiantim Offline
Thanks. Haven't spoke to Ralph in a few years but as soon as I thought about it, I realized Ralph would say "slower is better for filtration"...
So I think I'll just go the normal route and set one filter up as a bypass.
#3378603 - 05/22/14 06:27 PM Re: Can MotorGuards run FULLFLOW for Transmission? [Re: canadiantim]
morris Offline
Loc: ks, wichita
here is the latest info i have.
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. ONLY use high pressure hose. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
