Harrop's Howler
by Shannow
02/06/16 05:35 AM
2002 GMC Yukon Climate Control Problems
by Kgrant
02/06/16 01:11 AM
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
02/06/16 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
02/05/16 11:08 PM
GM Oil Life Update
by CapitalTruck
02/05/16 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
02/05/16 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
32 registered (Bookmaker, Char Baby, Boomer, bourne, d00df00d, billt460, 7 invisible), 545 Guests and 192 Spiders online.
56834 Members
66 Forums
244296 Topics
Page 1 of 2 1 2 >
#3371705 - 05/14/14 05:48 PM Conventional 75w-90 non limited slip?
Drew99GT Offline
Loc: Colorado Springs
Does anyone know if any of the big name brands make a conventional 75w-90 that does not have the limited slip additive? Valvoline used to but now it has the limited slip stuff. Thanks!
#3371708 - 05/14/14 05:50 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
PandaBear Offline
Loc: Silicon Valley
What is the reason you do not want the limited slip additive?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#3371714 - 05/14/14 05:54 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
Drew99GT Offline
For use in a manual transmission.
#3371719 - 05/14/14 05:58 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
KD0AXS Offline
Loc: Nowthen, MN
I've got some Shell Spirax HD 80W-90. Doesn't say anything about LS on thebot tle, so I'm guessing it doesn't have the friction modifier.
http://www.epc.shell.com/Docs/GPCDOC_X_cbe_26680_key_140003389066_200912102033.pdf
2014 Hyundai Elantra Coupe - M1 AFE 0W-30
2013 Jeep Wrangler JKU - PP 5W-20
2005 Ford F-350 4x4 5.4 - Maxlife 5W-20
2000 John Deere 425 - Rotella T6
#3371724 - 05/14/14 06:03 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
Drew99GT Offline
I need 75w-90 for cold climates.
#3371734 - 05/14/14 06:12 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
KD0AXS Offline
Loc: Nowthen, MN
Can you even get a conventional 75W-90? I've only seen it in synthetic.
How about Amsoil 75W-90 manual trans fluid?
http://www.amsoil.com/shop/by-product/tr...ar-lube-75w-90/
#3371747 - 05/14/14 06:20 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
gomes512 Offline
Loc: Chicago, IL
No 75w-90's in conventional form come to mind. However, Pennzoil has a syn 75w-90 GL-4. The product data sheet mentions it as an ideal fluid for manual gear boxes and does not mention LS additives.
Meanwhile their product data sheet for the syn 75w-90 GL-5 states it's ideal for LS diffs and has a LS additive.
Last I checked, both fluids are on Amazon. But the 75w-90 GL-4 listing has an incorrect product description. They copy and pasted the info from the GL-5 product.
Here's the product sheets if your interested:
http://www.pennzoil.com/wp-content/uploads/2012/02/Pennzoil+Synthetic+75S-90+GL-4+GL-5+ALL.pdf
#3371796 - 05/14/14 07:03 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
Bandito440 Offline
Loc: The County of Dr. Moreau
I have some conventional Valvoline 75w-90 in my stash. It's not marked LS, and I bought it in 2012. The Forester has it in the manual transaxle and rear diff. No problems in 18,000 miles!
'13 Forester 2.5X 5MT - NAPA 0w-20 & Wix 57830
[this space available]
#3371846 - 05/14/14 07:44 PM Re: Conventional 75w-90 non limited slip? [Re: Bandito440]
Wheel Offline
Loc: Upstate NY
[How about Subaru Extra-S ? It's a 75w-90, and one of a few that works safely in their manual transmissions. It is also a GL-5 rated fluid.
Edited by Wheel (05/14/14 07:47 PM)
Edit Reason: spelling
#3372003 - 05/14/14 10:27 PM Re: Conventional 75w-90 non limited slip? [Re: Bandito440]
Drew99GT Offline
That is what I've been using on my Corolla; it's been the best fluid I've used. Synthetic 75w-90, even GL-4s have been notchy. I'm apprehensive about using Valvoline anymore since it now contains limited slip friction modifier!
#3372097 - 05/15/14 12:11 AM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Mobil Delvac 75w-90 is, of course, synthetic, but is not marketed for limited slip and meets GL-5 and MT-1.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3372540 - 05/15/14 01:57 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
i812 Offline
Loc: Central, FL
Eneos comes to mind in which I have seen at NAPA stores. Only issue its synthetic. Eneos GL-5 75W-90
Edited by i812 (05/15/14 02:00 PM)
'13 Outback Limited 3.6R
#3372654 - 05/15/14 04:13 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
OVERKILL Offline
Loc: Ontario, Canada
You can probably get it from a Ford dealer. They require you add the LS additive separately so you know the stuff they sell doesn't have it.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3372980 - 05/16/14 02:29 AM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
Whitewolf Offline
Loc: MI, USA
Try gmpowertrain.com for a list of all the major approved products. GM part #88863089.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
#3373686 - 05/16/14 09:24 PM Re: Conventional 75w-90 non limited slip? [Re: Drew99GT]
aquariuscsm Offline
Loc: South Texas,USA
Interesting. I wonder if dino GL4`s will give smoother shifting over synth GL4`s? I have a case of Pennzoil Gear Plus 80W90 GL4 that I`ve never tried.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
Page 1 of 2 1 2 >
