Need help with Oil choice
WV
1995 Honda accord. 232,000 miles. Only runs about 3000 miles every six months but they are all stop and go short trip hard miles. I've been changing the oil for several years with Syntec full synthetic every six months, pure one filter. Recently, I had scratches in the cam and it was getting worse. So I, myself changed the cam (used), rockers (used), timing belt (it was close to time to do it and it had to come off when the cam came out), balance belt, water pump, oil pump (it was suspect and 20 years old but it did pass spec), all the seals along the way, timing covers, and drive belts.
While in there, I noticed a lot of varnish and even a trace of sludge in a couple places. I've owned this car for 7 years and always used synthetic oil never going more than 5000 miles between changes even when it was driven 40,000 miles per year for awhile. I've used several different brands but syntec for the last four at least.
In my mind, the oil is somewhat suspect although people tell me the cam probably wasn't heat treated correctly. So, since the car isn't driven much AND because they are all hard miles:
Should I get better oil, do I NEED to get better oil? If so, which oil? It only takes four quarts, I'm not worried about paying for four quarts of even Redline every six months. Trust me, I just paid for $500 worth of Honda parts, I don't want to change the cam and rockers again. BTW, it's hard to believe because there is a well of oil under the cam and it gets dipped in oil the first rotation on start up.
And I have a 2000 legacy with 261,000 and it's driven about 20,000 miles per year. I use the same oil and filters. When I've had it apart there is no sludge and very little varnish. Maybe the oil pump was bad? I just think maybe I should get better oil for the Honda if I'm only going to change it every six months anyway.
How'd you manage to get sludge and varnish using Syntec with a 5000 mile/6 month OCI ?
This is the question. It kind of blew me away. Since I haven't seen it with the Subaru. Maybe the oil pump was going bad? And the last few years were 6 months/3000 miles...
The old oil pump didn't feel like the bearing was grinding and there wasn't much play in it but I never tested it for volume because I don't have that equipment. It was over the average lifespan, according to a honda tech and I thought I was close to changing it anyway with the timing and balance belt although that's not really true, changing the oil pump on a honda 4 is a whole different animal.
I dont think Castrol is the best cleaning oil, but there shouldn't be sludge and varnish with those short intervals. Has the PCV valve been changed? Moving forward, I would use Pennzoil Platinum or Pennzoil Ultra, or the new PPPP or PUP. Those are all great cleaning synthetics that SHOULD clean up the mess in there. I would still check the PCV valve though.
SORRY SUPERTECH, not Syntec... Wally World Brand...
Supertech synthetic is a good oil, my guess is that the varnish was long formed by the previous owner. Pennzoil Platinum has a bit better cleaning ability if you want to step up.
Fighting varnish once it's formed is difficult.
Just thought the varnish would come out in 7 years of changing the oil. Maybe I need to change more often due to the super short trips. Most trips are 3 miles, it goes weeks without driving more than 5 miles on a trip and it is driven almost every day for super short trips. Maybe every three months which is 1500 miles? I just don't want to groove another cam. I was lucky someone sold me a used cam and rockers for $40. No way I'll get that lucky again.
I guess your driving style is really hard on an engine. If the engine is always "warming up" and never reaches normal temp there could be fuel dilution in the oil. Don't know if there is metal to metal contact, or just normal wear for an old car. I don't think you should expect synthetic oil to overcome these harsh conditions and the best plan will be to run conventional oil and change it out every 2 or 3 months.
OK, I understand. Although Supertech is so cheap in the five quart bottle I might as well just keep buying it and change it more often. It's only $17.50 for 5 quarts.
Yes, that's a good price. I know you want to take care of the new parts. A 1500 mile interval sounds like overkill for modern motor oil but Honda's severe service oil change schedule for your model is probably 3000 miles or 3 months, which ever comes first.
IMO...Castrol Syntec Blend is some really fine oil. I've used it in a few runs and all I can say is the engine ran smooth. I mixed a blend of 2 Gray Quarts of the Castrol SynBlend 20w50, 5w20 and 2 quarts of Castrol "Full Synthetic" Syntec (Before it became Edge with Syntec)...Kmart Gallon Jug clearance specials....Full Synthetic 5w30. Total of 6 quarts for 3 8K runs in my vehicle as well as neighbor's vehicles. Not a problem. No make up oil in the Summer Heat. All oils were API-SM
All these were clearance oils except for the SynBlend 5w20 Gray quarts.
BTW...there are some very good cleaners you can use for your internal engine clean up. I used 2 long doses of Kreen with very good results. There is also the old time favorite dosing of MMO that can be used as an option.
short tripping will cause just as much damage to the engine, more so than one that sees more, if not longer running miles/operating times.
Ever heard of the old lady's automobile story? low miles, frequent short trips (go to the corner store 1 mile away from house and back, sunday church, send a mail or see doctor, etc. even with low miles, the engine still looks varnishy due to (a) condensation, (b) fuel dilution in oil, (c) engine didn't get sufficiently hot enough for some of the additives in oil to "activate" itself and starts doing it's job (keeping engine clean, neutralise acids, coat the cam lobes or plate the bearings, etc.)
Q.
I don't think that any oil is going to make a difference.
The cam may have merely had its hardening worn through after many hours and miles. Once that happens, wear will be very rapid.
Also, I've seen cases where a cam lobe experienced minor scratching that never got any worse.
The varnish you're seeing may have been there for many years.
I'd have thought that frequent changes with any oil would have cleaned it up, but apparently not.
Having done all of this work to this engine, have you at least replaced the PCV valve and checked the line to it for clogging?
A stuck valve or clogged line will cause varnish over time.
I don't think that more frequent drains will help you either, since 3K is already pretty short, even for a car driven only short trips.
One thought might be to take the Accord for a couple of the longer drives that the Roo must be used for a couple of times per month. If the Subie is doing 20K a year, it's clearly getting some use.
If you drove the Honda on a couple of these longer trips a couple of times each month, this would at least get the oil up to temperature and keep it there for some time, which would evaporate all of the moisture in it. This might help to reduce the varnish that you've observed.
I'll second Merkava in that Maxlife would probably be a good choice for the engine, and it's readily available in 5W-30. Honda also allows for the use of a 10W-30 at ambient temperatures above 20F, so you could use that grade in the warmer months if you happen to see it at a deal price.
Think about how much cleaning the Syntec accomplished in the last seven years.
Previous use/abuse may have led to the wear and sludge, with the last seven years improving the innards.
Short tripping and below warmed up driving is demanding on any engine and oil.
Kudos to you on your work, keep posting the developments. Maybe a UOA and some pics to start a reference point!
Thanks, I think that is one solution, use the honda for a couple of the highway trips each month. Max life is good stuff, I'm not sure it's better than Super Tech, definitely as good.
The thing is I got the car from my dad and I know he did oil changes at least every 5000-6000 miles with dino at the dealer with a Honda filter. The last year he had it he got a little more lax because he planned to trade it and I bought it instead because it had been garaged in NC and mostly well maintained. It still doesn't have rust on it for example. It only had 129,000 when he was going to trade it.
Of course my Mom was driving it and lots of short trips.
UOA wouldn't be a bad idea. It's interesting that a few days after I change the oil normally, the bottom of the dipstick oil is darker than farther up. A few days after doing this, which included pulling the pan so I got the pan really clean, the oil looks brand new all the way down the stick. There was definitely some sludge in the bottom of the pan. I was surprised that there isn't a magnet in the oil pan.
