Observations on Workplace corrosion
by Vdubuk
07/29/16 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
07/29/16 12:08 PM
First time flushing an 05 Tacoma
by Back40
07/29/16 11:53 AM
600-year-old plumbing works better than modern
by HTSS_TR
07/29/16 11:48 AM
Shopping for brand-new F-150
by jay929
07/29/16 11:35 AM
Audi Broken Oil Control Rings - Why???
by SonofJoe
07/29/16 11:27 AM
Royal Purple VS Moblieone?
by 340six
07/29/16 11:09 AM
Condensing down to 1 vehicle
by krismoriah72
07/29/16 11:04 AM
Ford Focus door strip coming off
by FordBroncoVWJeta
07/29/16 10:41 AM
Windows 10 doesn't work on dial up speed
by Blaze
07/29/16 10:35 AM
Rotella T5 15w40
by JeepWJ19
07/29/16 10:33 AM
Motorkote ??
by Moondawg
07/29/16 08:53 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
73 registered (aquariuscsm, 4WD, Back40, aircooled, 69GTX, Andrei, 6 invisible), 1925 Guests and 12 Spiders online.
58632 Members
66 Forums
252401 Topics
Page 2 of 2 < 1 2
#3371373 - 05/14/14 11:10 AM Re: AC Compressor Load on Engine [Re: A_Harman]
440Magnum Offline
Loc: Texas
Originally Posted By: A_Harman
Setting a higher temperature on the A/C control would make the compressor clutch cycle off more often, which would save fuel.
Actually, almost NO automotive systems work that way. The HVAC maintains the temperature of the evaporator coil at about 35 degrees F (or as close as it can get). If you set the temperature to warmer, it may slow the fan down on fully automatic climate controlled systems and that does help. But on most systems, it just blends in some warm air from the heater core and does nothing to reduce the load on the compressor.
Fan speed always has more effect- slower fan speed means that the compressor doesn't have to run as much (or if its a variable-displacement compressor, it can run at a lower displacement) to keep the evaporator coil at the target temperature.
Even older systems (for example, Chrysler Airtemp with the old V2 and RV2 compressors) ran the compressor all the time, but used an evaporator-pressure regulator valve and variable thermal expansion valve to "throttle" the system. The EPR valve would begin to block the suction side of the compressor when the returning refrigerant temperature got down to about freezing, which reduced the compressor head pressure, and in turn reduced the load on the crank. But mainly, it made the system stupid-slow to respond to a high load. All my EPR systems got converted to cycling-clutch systems when they got converted to R-134a.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3371476 - 05/14/14 12:47 PM Re: AC Compressor Load on Engine [Re: Chris142]
zzyzzx Offline
Loc: Baltimore, Maryland, USA
Originally Posted By: Chris142
now lets throw a variable displacement compressor into the mix
I suspect that not enough people have one of those to comment. I do, and when driving that car I just leave it on. On my other car witha normal compressor that turns on and off, I only have the A/C on when not accelerating, since turning the A/C on is roughly equivalent to a "drop anchor" button.
#3371523 - 05/14/14 02:11 PM Re: AC Compressor Load on Engine [Re: actionstan]
accent2012 Offline
Loc: Orlando, FL
On my older car, turning on the AC noticeably bogged the engine making it run at higher RPMs in idle. Acceleration time would also grow by a second or two. IF I'm on the highway and wanted to pass someone in that car I had to turn it off so as not to take too long lol. It felt like the car lost some weight lol.
Would cycling the AC clutch all the time cause it to wear out faster? If that's the case, wouldn't it just be better to run the AC at max so the clutch doesn't engage?
I was told this bogging down the engine was much worse in the older days. I knew someone who drove a first-generation Ford Fiesta from the 80s with AC. The car would lose half of its power with it engaged!
Edited by accent2012 (05/14/14 02:13 PM)
Hyundai Accent 2012
#3371531 - 05/14/14 02:24 PM Re: AC Compressor Load on Engine [Re: accent2012]
zzyzzx Offline
That could be said for all or most 4 cylinder cars of the era yes.
#3371539 - 05/14/14 02:34 PM Re: AC Compressor Load on Engine [Re: zzyzzx]
dishdude Offline
Loc: Phoenix
I had a '95 Neon that when new, I couldn't tell when the compressor cycled. By around 150-160k, I'd lose a ton of power each time the compressor cycled.
I think smaller displacement engines that don't have a lot of low end torque are the ones that really get bogged down.
#3371546 - 05/14/14 02:44 PM Re: AC Compressor Load on Engine [Re: actionstan]
exranger06 Offline
Loc: Guilford, CT
Most cars have a wide open throttle relay that will automatically turn the AC compressor off when you're accelerating hard.
2006 Ford Ranger Sport
1992 Honda Accord EX
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek (wife's)
#3372471 - 05/15/14 12:36 PM Re: AC Compressor Load on Engine [Re: zzyzzx]
artificialist Offline
Loc: Florida
Really? I'm used to seeing them on the GM 2.2 OHV, 3100, 3400, and all Ecotec engines. They were so common, that it was the first time I saw a clone of a compressor made brand new in China.
Anyway, the burden the A/C put on the car varied by compressor design. My father installed retrofit kits in the late 1960s and early 1970s. The kits were not recommended for I6 and smaller engines, and that was because they had a huge 1-cylinder compressor.
Dad did have a car where the AC was an enormous burden. It was a 1987 Hyundai Excel. The A/C compressor disengaged at full throttle, and because of how weak that engine was, there were plenty of times when he had no A/C at all.
2010 Lancer Ralliart Sportback
#3372878 - 05/15/14 10:02 PM Re: AC Compressor Load on Engine [Re: actionstan]
1 FMF Offline
Loc: CT
Originally Posted By: actionstan
Hello All,
I was wondering.. when you turn on the AC in a vehicle and the compressor starts putting load on the engine.. does it put the same load on the engine all of the time? Or does it depend on how fast the blower motor is running.
For example if you use the AC but keep the blower on low, will you save fuel/load on the engine, V.S. running the blower on high with the AC on?
Just wondering because it may make more sense to run it high.. then turn it off when I am comfortable enough, then run it high again. I have a 99 SL1 and the compressor basically completely kills its power, and in the 2013 it idles rougher with the AC on so I like to minimize use as much as possible.
Thanks,
there are two types of compressors, clutch cycling and variable displacement.
for either one, the load that the compressor puts on the engine is directly proportional to the heat the refrigerant is moving from the evaporator to the condenser and how well the condenser is shedding that heat. so on a hot day with your blower on high- the most hot air is flowing over the evaporator coil to be cooled, putting the most heat in the system. now if your parked and you notice your radiator fans kick on high speed, that's because of all the heat in the refrigerant and it's unable to be shed at the condenser easily- high side pressure of the AC system is very high and that pressure difference from what the compressor is pumping is the load placed on your engine.
on a variable displacement compressor which is what most cars have now, i don't know what model years the clutch cycling got mostly phased out, the compressor varies its output (pressure) based on internal valving to keep low side pressure above 30 psi for r134a refrigerant. so when heat load is low the compressor swash plate is more flat and it's pistons pump less, when heat load is high the swash plate is angled most and the pistons pump at max capacity, as heat builds in the system and high side pressure rises, that pressure between low side and high side of what the compressor is causing is the load placed on the engine. you will never hear a normally operating variable displacement compressor clutch cycle off unless it's turned off or you're low on refrigerant and the clutch is tripped by the low pressure sensor.
in a clutch cycling orifice tube system, when it does cycle off under normal conditions that's because the heat load on the system is very low causing that so just prior to it cycling off the compressor is placing the least amount of load on the engine it could be.
and in either case a blower setting on low vs high puts less mass heat flow over the evaporator coil = less heat put into refrigerant = lower system pressure = less load on engine regardless of outside temperature.
#3373790 - 05/17/14 12:07 AM Re: AC Compressor Load on Engine [Re: actionstan]
Barkleymut Offline
Loc: Richmond, VA
I learned to drive in a '82 Corolla station wagon with AT. With the AC on I often wondered if I could get up certain hills. At stoplights the AC quit running until you gave it some gas. That little car was tough, but very unpleasant to drive.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#3373849 - 05/17/14 05:17 AM Re: AC Compressor Load on Engine [Re: actionstan]
SteveSRT8 Offline
Loc: Sunny Florida
Sounds like my Dad's old Corona. The AC clunked on and half your HP vanished!
At least it was cold. But the constant vibe and cutting in and out was annoying as the dickens...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3373864 - 05/17/14 06:03 AM Re: AC Compressor Load on Engine [Re: actionstan]
Colt45ws Offline
Loc: Central Washington
My old '98 Cavalier had a 2.2L OHV w/ 3-speed AT and the A/C button was a turbo button. I remember reaching over and hitting that button all the time when I was driving to school or work in Las Vegas. Also made it vibrate a lot at idle. I think it was literally a 20-21 second 0-60 vs. 14 or 15 seconds. It was horrible. I wished it had a WOT cutout.
Edited by Colt45ws (05/17/14 06:08 AM)
-Colton
2002 Ford Crown Vic PI, 187k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
Page 2 of 2 < 1 2
