Who watches the oil co's?
by Camprunner
07/25/16 02:44 PM
Magnetec "Edged" out?
by ARCOgraphite
07/25/16 02:34 PM
Let's talk RUM
by car51
07/25/16 02:23 PM
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
07/25/16 01:18 PM
Making tacos at home
by Reddy45
07/25/16 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
07/25/16 11:38 AM
Power Steering Fluid
by DWC28
07/25/16 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
07/25/16 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
07/25/16 08:05 AM
kohler courage 15 issues
by tomm22
07/25/16 07:58 AM
Small overlap crash test?
by Huie83
07/25/16 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
07/25/16 07:20 AM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
90 registered (4WD, Alfred_B, 182RG, AIRJAC3, 87sammy, 2015_PSD, 9 invisible), 2182 Guests and 24 Spiders online.
58589 Members
66 Forums
252234 Topics
Page 1 of 2 1 2 >
#3371677 - 05/14/14 05:08 PM Radial pull: Which tire caused it?
Nayov Offline
Loc: ME
I bought some tires on line, had a shop install those, but immediately experienced a drift to the right while driving (checked PSI). I thought I could live with it, but after 4,000 miles I couldn't take it anymore and went to China*Mart for a R&B.
I had them rotate the fronts straight back to the rear; the rears crossed to the front (FWD rec. pattern, and in the OM).
Problem solved.
O.K., so which tire was the culprit? Also, will the offending tire 'fix' itself, or should I never rotate again (or chose another pattern)?
#3371682 - 05/14/14 05:12 PM Re: Radial pull: Which tire caused it? [Re: Nayov]
beast3300 Offline
Loc: Ohio
Right front was the pull. Most likely you will need to keep that tire on the left side of the vehicle.
Edited by beast3300 (05/14/14 05:13 PM)
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#3371684 - 05/14/14 05:16 PM Re: Radial pull: Which tire caused it? [Re: Nayov]
CapriRacer Offline
Loc: Somewhere in the US
Problem solved.
I don't think you can tell from the information provided.
First, pull is generally a property of the SUM of the conicity of the 2 front tires.
So rotate one of the rear tires to the front and see if you have a pull after that. If so, then it is likely the one rotated from the rear.
If not, it is likely the one left on the rear.
But it is a bit more complicated than that.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#3371782 - 05/14/14 06:54 PM Re: Radial pull: Which tire caused it? [Re: Nayov]
Mr Nice Offline
Loc: Orlando, FL
If you bought the tire at a tire shop and you did have 'radial pull'
Would the tire shop replace a brand new tire?
2007 Civic EX
2006 Accord SE
2005 RSX base
#3371784 - 05/14/14 06:55 PM Re: Radial pull: Which tire caused it? [Re: CapriRacer]
stevejones Offline
Loc: Midwest
I know I'll catch a sh!tstorm for this, but lemme give you my $.02 worth: I only rotate tires is there's a pull or uneven wear. Especially on FWD vehicles. If the wear is even & the track is true, I don't mess with it. I'll wear out the two front tires & replace them (same brand & model, of course) before rotating.
Edited by stevejones (05/14/14 06:56 PM)
#3371797 - 05/14/14 07:04 PM Re: Radial pull: Which tire caused it? [Re: Nayov]
yonyon Offline
Loc: NJ, USA
Have you tried contacting the seller or manufacturer of the tires? Some will direct you to a tire store that can measure the pull from each tire and remedy the problem by matching pairs or replacing one or more tires.
#3372239 - 05/15/14 08:01 AM Re: Radial pull: Which tire caused it? [Re: yonyon]
CapriRacer Offline
As a general rule, tire pull is covered by a new tire warranty
- BUT -
You can wear conicity into a tire, so generally there are time and wear limitations.
I doubt the tire manufacturer will honor any warranty on used tires.
But the idea of using a Hunter GSP9700 to measure the pull and develop a best pairing has merit.
CapriRacer
#3372519 - 05/15/14 01:36 PM Re: Radial pull: Which tire caused it? [Re: stevejones]
Miller88 Offline
Loc: Onondaga County
I always had that mentality. Still do. I used to only rotate in the spring when I would switch from winter to rest-of-year tires.
Boy was I surprised when I learned my Focus wears the rear tires quicker!
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3372564 - 05/15/14 02:38 PM Re: Radial pull: Which tire caused it? [Re: Miller88]
Ken2 Offline
Loc: Washington St.
Does that Focus have adjustable rear wheel alignment? That could be the problem.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#3372722 - 05/15/14 05:41 PM Re: Radial pull: Which tire caused it? [Re: yonyon]
Nayov Offline
Loc: ME
Nope. Not worth it especially now that it's 'fixed' with a Band-Aid solution, but let this be a consideration to anyone thinking of buying tires on line. whistle I got those at DTD on line, but there are no brick-and-mortar DTD stores around here as far as I can tell.
#3372809 - 05/15/14 08:33 PM Re: Radial pull: Which tire caused it? [Re: Ken2]
Miller88 Offline
Ford specifies a vague amount of camber and toe in the rear. I'm sure both are out.
#3373011 - 05/16/14 06:04 AM Re: Radial pull: Which tire caused it? [Re: Nayov]
CapriRacer Offline
Problem solved.
So what did you do?
CapriRacer
#3373597 - 05/16/14 07:39 PM Re: Radial pull: Which tire caused it? [Re: CapriRacer]
Nayov Offline
Loc: ME
Problem solved.
So what did you do?
Nothing further than what I did in the original post. They are cheap Generals on an old econo-box, and I am satisfied with the way it tracks, but I will rotate them again in 10,000 miles, or have Walmart do it, at which point it will be interesting to see how it acts.
#3373870 - 05/17/14 06:11 AM Re: Radial pull: Which tire caused it? [Re: Nayov]
CapriRacer Offline
Prediction: The rotation will cause the pull to come back.
CapriRacer
#3374163 - 05/17/14 04:21 PM Re: Radial pull: Which tire caused it? [Re: CapriRacer]
Nayov Offline
Loc: ME
correct. banana After a few miles under my seatbelt in certain conditions it now drifts to the left, but it's tolerable and not as hard of pull a when it did to the right...the crown of the road is a marvelous corrective tool.
Page 1 of 2 1 2 >
