Manual says every 10 K on oil changes
by ceast
30 minutes 40 seconds ago
Brake fluid ageing?
by LucasDK
33 minutes 49 seconds ago
If Anybody has 60K Lying around
by GumbyJarvis
Today at 02:03 PM
144$ lot of 48 Fl-400s/L20195 Eq Filters
by GumbyJarvis
Today at 01:29 PM
AT Whine
by DWC28
Today at 01:14 PM
GM AutoTrak II fluid
by nthach
Today at 12:49 PM
GM 2500HD 75w-90 or 75w-110
by Stewart Fan
Today at 12:03 PM
tire question
by Durango
Today at 12:02 PM
Winter's Over, Time to Start Next Year's Firewood
by doitmyself
Today at 11:54 AM
Heard of Hemi Tick- is there "Hemi Shudder"?
by JennyHemi
Today at 11:07 AM
Lost my mind, about to buy Genesis Coupe 3.8
by FutureDoc
Today at 10:27 AM
Tire Sizing Help
by coopns
Today at 10:23 AM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
94 registered (2010Civic, Al, 69GTX, 2009Edge, 901Memphis, 01rangerxl, 14 invisible), 1996 Guests and 234 Spiders online.
57779 Members
66 Forums
248413 Topics
#3372743 - 05/15/14 06:20 PM Furnace Condensate Line Clogged
JerryBob Offline
Loc: Colorado
Does anyone know how and where to unclog a condensate line on a Carrier furnace (circa 2010)? The unit has started creating puddles since I've turned on the AC.
The photo below shows where I think it is, but I am not sure. Does the black corrugated tube on the left that goes into the white housing (the area with all the tags hanging off of them) need to come off and flushed out somehow?
I think the leak is coming from the white PVC drain on the extreme lower right. I made sure that the piece going to the floor drain is not clogged, so I think the clog is somewhere within the unit.
Any advice to save a service call would be greatly appreciated.
Certified Filter Cutter - License #F-23567 Expires 12/2019
#3372762 - 05/15/14 06:54 PM Re: Furnace Condensate Line Clogged [Re: JerryBob]
Corvette Owner Offline
Loc: Waldorf, Maryland
Can you use air pressure with a rag (to seal one end) to blow out line? That's how I clear mine.
Edited by Corvette Owner (05/15/14 07:08 PM)
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#3372768 - 05/15/14 07:18 PM Re: Furnace Condensate Line Clogged [Re: JerryBob]
laserred96gt Online   content
Loc: Florida
What I see in the pics is your gas line, PVC drain pipe connects to your evaporator coil which is probably on top of you furnace. There should be a service port ( where you can pour vinegar to help keep the drain clean, if they even installed one ) you can try to gently blow it out, or go outside find where the drain comes out and try to vacuum it. Im surprised the float switch hasn't tripped, or if it even has one.
Edited by laserred96gt (05/15/14 07:22 PM)
96 Mustang GT: Maxlife 5W30
04 E-150, 4.6, 200K, Royal Purple 5W30
11 Camry 2.5, 41K, Synpower 0W20.
#3372773 - 05/15/14 07:30 PM Re: Furnace Condensate Line Clogged [Re: JerryBob]
bepperb Offline
Loc: Milwaukee, WI
Those black tubes are for condensate from the heat exchanger. Look for something above the furnace itself. Also, I see the pvc pipe. Don't be afraid to remove the panel below the one you've removed (with the little window to view the diagnostic led), though it will have a switch and the furnace won't run with that one removed.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#3372777 - 05/15/14 07:37 PM Re: Furnace Condensate Line Clogged [Re: JerryBob]
JC1 Offline
Loc: Oshawa, Ontario Canada
Jerrybob,
Your condensate trap is that white box with the two black hoses in it. It gets all gunked up with crud. You'll need to remove the lower door to get it out. There are two tabs that you squeeze on each side and pull the trap up. You can rinse it out with water from a tap or soak it in vinegar for a while.
Here is a link to the part.
http://www.repairclinic.com/PartDetail/Drain-Pan/319830402/2347566
I had a similar furnace. Just replaced it last December due to the heat exchangers rusting out.
Regards, JC.
#3372779 - 05/15/14 07:37 PM Re: Furnace Condensate Line Clogged [Re: JerryBob]
marshall25 Offline
Loc: Indiana
If it's from the AC, your condensate pan on the coil is probably blocked, then over flowing and draining out through the furnace. Pull the cover off your A-coil and check it out.
#3372802 - 05/15/14 08:14 PM Re: Furnace Condensate Line Clogged [Re: JerryBob]
Chris Meutsch Offline
Loc: Cincinnati
My service tech pours bleach down the drain pipe coming straight from the A-coil every year and tells me to do it every 3 months to keep things clean. I never do, but never had a problem. I second what others have said, it's the coil pan drain.
"I bow to the master troll engineer20."
---cptbarkey, 3/21/16
#3372847 - 05/15/14 09:16 PM Re: Furnace Condensate Line Clogged [Re: Chris Meutsch]
DSparks Offline
Loc: Texas
Pvc fittings at very bottom left of the pic is the drain .....the evaporator sits in a pan and the water runs out of this drain to the outside...basically its plugged up with slime and crud.....2 ways to clean it...quick way is to blow air from outside and should clear it but will probably be temporary but will buy you some time...or take the lower panels and fittings apart and maybe remove coil and pan completely to clean it all real good....just depends how bad it is...
#3373308 - 05/16/14 01:34 PM Re: Furnace Condensate Line Clogged [Re: JerryBob]
ironman_gq Offline
Loc: MN
Our HVAC tech uses compressed air to blow out the lines and clear the clogs, he then follows up by pouring bleach down the lines to kill the mold and crud that eventually clogs the lines.
