I bought some tires on line, had a shop install those, but immediately experienced a drift to the right while driving (checked PSI). I thought I could live with it, but after 4,000 miles I couldn't take it anymore and went to China*Mart for a R&B.
I had them rotate the fronts straight back to the rear; the rears crossed to the front (FWD rec. pattern, and in the OM).
Problem solved.
O.K., so which tire was the culprit? Also, will the offending tire 'fix' itself, or should I never rotate again (or chose another pattern)?
Problem solved.
