wheel bearing grease
by meborder
07/30/16 06:59 AM
My car audio build thread
by dan_erickson
07/30/16 06:08 AM
Pegasus PS737 Cut Open. Unknown Mileage / Oil
by Farmer
07/30/16 05:45 AM
Napa Gold 1372, 4.5 Months, 8500KM.
by Farmer
07/30/16 05:38 AM
lubriplate 1200-2
by buffalobob
07/30/16 02:49 AM
How do you politely say no to people?
by motor_oil_madman
07/30/16 12:39 AM
To change or not?
by ram_man
07/29/16 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
07/29/16 11:20 PM
Camaro "How its Made" TV show Observations
by SumpChump
07/29/16 11:08 PM
Wondering if sitting with few quick starts degrad
by corndogzombie
07/29/16 10:51 PM
whole hog cook w/ pics
by 04SE
07/29/16 10:12 PM
redo a/c in 1994 dakota 2wd
by bmwjohn
07/29/16 09:37 PM
jractk, LatitudeDancer, AKN, NickGB, Marcusd1979
58645 Registered Users
63 registered (alarmguy, 97f150, AnthemBassMan, AirgunSavant, Astro_Guy, 04SE, 3 invisible), 1510 Guests and 9 Spiders online.
58645 Members
66 Forums
252433 Topics
#3371902 - 05/14/14 08:34 PM 02 GMC 2500HD Duramax, Delo 15W-40, 8,622 mi
audi_guy Offline
Loc: Metro Atlanta GA
Miles on oil: 8,622 8,247
Miles on Unit: 206,925 198,303
Makeup oil: 1 qt
Code:
           Delo    Rotella T6
           400 LE
ALUMINUM      4      2
CHROMIUM      0      0
IRON          7      6
COPPER        2      2
LEAD          0      1
TIN           0      4
MOLYBDENUM   84     55
NICKEL        1      0
SILVER        0      0
TITANIUM      0      0
POTASSIUM     9      0
BORON       424     54
SILICON       4      3
SODIUM        4      5
CALCIUM    1491    974
MAGNESIUM   498   1232
PHOSPHORUS 1144   1192
ZINC       1320   1409
BARIUM        0      0
SUS Viscosity @ 210F    69.6    71.1
cSt Viscosity @ 100C    12.86   13.23
Flash point in F        450     415
Fuel %                  <0.5    <0.5
Antifreeze %            0.0     0.0
Water %                 0.0     0.0
Insolubles %            TR      0.2
TBN                             8.5
OLM light came on at about 8400 miles on the oil. It lied again. grin
Asked for the TBN but Blackstone apparently didn't run the test.
Not bad for a $11 and change per gallon oil that was on sale.
Going to change the fuel and oil filters, top off the oil, clean and re-oil the air filter, reset the OLM, and keep on driving.
ACDelco oil filter
Banks RamAir with K&N clone filter
Wix High Efficiency fuel filter.
Edited by audi_guy (05/14/14 08:42 PM)
01 Audi S4 2.7T Quattro GC 0w30
07 Audi A6 4.2 FSI Quattro Castrol 0w40
02 GMC 2500HD Duramax CrewCab 4x4 Rotella T6 5w40
86 BMW K75C VR1 Dino 20w50
#3371986 - 05/14/14 10:10 PM Re: 02 GMC 2500HD Duramax, Delo 15W-40, 8,622 mi [Re: audi_guy]
29662 Offline
Loc: sc/fl
Both uoa's look excellent. Thanks for posting them.
#3372159 - 05/15/14 05:54 AM Re: 02 GMC 2500HD Duramax, Delo 15W-40, 8,622 mi [Re: audi_guy]
dnewton3 Offline
Loc: Indianapolis, IN
Sadly, your engine is nearing the end of it's useful life. You can only expect perhaps 500k+ miles from it ... grin2
Seriously, the Dmax is about the easiest on oil of all the light-duty diesels ever made. Their UOAs are typically so boring they're not worth posting, and that's a good thing. Everything looks fine in your sample. I note that the insolbulbes is "TR"; I've not typically seen Blackstone state it that way, but I presume it to mean lower than .1 so it's very low. Your air filtration is doing well; leave it in place and don't touch it until the little meter says to do so!
That truck will rot before it stops running. Being an LB7, keep an eye out for fuel in the lube and just keep on truckin'!
Edited by dnewton3 (05/15/14 05:59 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3372186 - 05/15/14 06:47 AM Re: 02 GMC 2500HD Duramax, Delo 15W-40, 8,622 mi [Re: dnewton3]
audi_guy Offline
Well dang thought I had bought a truck to last. grin
Was wondering what that meter on the airbox was for.
Yep will watch for leaking injectors.
#3372189 - 05/15/14 06:53 AM Re: 02 GMC 2500HD Duramax, Delo 15W-40, 8,622 mi [Re: audi_guy]
A_Harman Offline
Loc: Michigan
With a K&N style filter on it, that airbox meter may never indicate a need for a filter change. I clean my K&N every year just to be sure.
Edited by A_Harman (05/15/14 06:54 AM)
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3372214 - 05/15/14 07:23 AM Re: 02 GMC 2500HD Duramax, Delo 15W-40, 8,622 mi [Re: audi_guy]
audi_guy Offline
got ya AH. Thanks.
#3454136 - 08/12/14 11:00 PM Re: 02 GMC 2500HD Duramax, Delo 15W-40, 8,622 mi [Re: dnewton3]
stockrex Offline
Loc: Michigan
unless you have a LMM with the darn 9th injector flooding everything :-).
07Ridgeline:33k,08Dmax:14k,10Fit:40k:90Toyota1Ton:88k
Oil Whisperer!*Fear the DINO*
#3454138 - 08/12/14 11:01 PM Re: 02 GMC 2500HD Duramax, Delo 15W-40, 8,622 mi [Re: A_Harman]
stockrex Offline
Loc: Michigan
did someone post some stuff about k&n letting in more dirt that factory?
