Not everyone will be familiar with this engine line, but lets use the Kohler K series single cylinder small engine. This question will apply to car/truck engines as well.
On the 12HP to 18HP models, the crankpin diameter & width is identical and rod is the same.
What I have noticed is that with proper maint, the high HP models have more wear on the crank in comparison to the smaller models.
So why would a manufacture think it is OK to increase HP ratings without increasing the surface area on the crankpin to support those greater loads?
Secondly, is there a calcuation the manufacture can use to determine how to size it?
