Nick1994
$100 site donor 2024
I posted at the end of January of the glitter look of what was in my oil after the oil change. Here is the link to the previous post: http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3262736/Metal_shavings_in_oil#Post3262736
I put 4,500 miles on Pennzoil Ultra 5w30 and a Wix filter. In the 4,500 miles I added 1/2 a quart of makeup and it was due for another top off when I changed it, it needs a new oil pan gasket that leaks pretty good only when I first start it up in the morning that I've been procrastinating changing. Almost 193,000 on the car now and I put in Pennzoil Ultra 10w30. I figured I'd use up the 10w30 from my stash for the summer. Some people thought from the previous post that the previous owner may have used a sealant in the oil to stop the oil leak because it was leaking when I bought it and that sealant that could have been "Restore" may be the glitter.
The chunks in the bottom of the pan are not magnetic and fall apart when you touch them, I'm thinking they're the oil pan gasket. I didn't cut open the filter this time, the last time when it had more glitter in the drain pan I cut it open and it looked great in the filter. This car still blows my mind. What do you guys think?
Clean drain pan when I started
