This is a strange one, and I'm not even sure I understand the symptoms entirely.
Our 2002 Malibu has felt down on power for a few months now. I've been trying to figure out what's going on by at least isolating "what" it's doing specifically, but even that has not been easy.
I came to the conclusion today that I think it's only down on power from about idle to ~3000 rpm. Above that, it begins pulling with normal gusto (or at least noticeably more). It drives like a vehicle with a lot of turbo lag, to me.
Additionally, the power delivery in that range under normal acceleration is almost "lumpy". It's almost a surge. Not to a degree that I think a passenger would question it, but it's noticeable.
I am not getting any codes. Fuel trims are no different than ever, about +2.34% to +3.12% long term on the highway at ~2000 rpm. Throttle position sensor readings are responding correctly. MAF values look realistic to me, up to about 150 g/s at WOT and near shift point. The timing seems to respond correctly.
Originally I thought it seemed just, down on power, but after flooring it a few times today I noticed that at almost all at once, nearly at 3000 rpm, it really starts pulling hard (okay, as hard as 170 hp will pull).
Any ideas? Things to check?
