I have a very small oil seep through the timing chain cover on my Mazda 3. I believe the cover has an RTV sealer applied at the factory and not the gasket (correct me if I'm wrong).
In any case, reading a thread by Ndx of a similar problem, I started to wonder if cleaning the area and applying some black or grey RTV to the cover and engine block joint where the seep is located would work.
The seep is very small and I think that some RTV "worked in" a bit with the finger might seal the small gap.
What do you think?
What do you think?
