1988 Cadillac Brougham-307 v8 124,779 miles
fill- Service pro XHD30 + Bosch 3423
duration- 4900 miles
qts added- 4 (DGauto 10w-40 SF)
current# Prev#'s , ,
aluminum- 23 18,19,23
chromium- 5 2,3,5
iron- 149 56,76,140
copper- 16 3,3,6
lead- 106 10,12,28
molybdenum-43 72,93,11
nickel- 0 1,1,0
manganese-2 1,1,2
silver- 0 0,0,0
titanium- 1 1,3,30
potassium-3 6,2,4
boron- 15 39,45,8
silicon- 16 12,10,10
calcium- 1920 2976,2681,2306
magnesium-25 15,16,19
phosphorus-679 1087,885,854
zinc- 900 1310,1021,1081
barium- 0 0,0,0
SUS visc.@210F- 69.9
Cst visc.@100C- 12.93
Flashpoint in F- 390
Fuel%- antifreeze%- 0
water%- 0
Insolubles%- 0.5
"Something has changed since the last sample. We found a lot more lead and tin this time,
showing some excess bearing wear. Iron and copper (steel and brass/bronze parts) shot up as well. This run wasn't much longer than the last, so it would've been nice if metals were steady. Silicon read high and it might be abrasive dirt getting past the air filter, so give it a quick inspection to make sure all is well. It might be from a harmless sealer/lube. The viscosity was thick, probably due to the 10W/40 you added. Watch oil pressure and stay under 4K miles for now. Check back."
This run was virtually all city and being stuck in construction. Less than 500 highway miles this time. last run was 50/50.
Also used DGauto (dollar general) SF 10w-40 for top-off as this one eats oil. I will not do so again, nor should anyone else. Air filter has about 17k on it at present.
Fuel filter, fuel pump, ignition module, oil PSI switch, and PS belt changed during this run.
chromium- 5 2,3,5
iron- 149 56,76,140
copper- 16 3,3,6
lead- 106 10,12,28
nickel- 0 1,1,0
manganese-2 1,1,2
silver- 0 0,0,0
titanium- 1 1,3,30
potassium-3 6,2,4
boron- 15 39,45,8
barium- 0 0,0,0
water%- 0
Insolubles%- 0.5
