Does anyone know if the over-sized filters will work on a 3800 Series II found in a 1999 Firebird? The car is new to me and I'm about to change the oil on it. I noticed the filter location is right towards the bottom of the engine and I don't know if the extra inch or so will cause any issues of debris hitting it or bottoming out on anything. I found a bunch of M1-201 filters (same size as the Fram PH3980/AC Delco PF52) which I know have the same threads and bypass specs as the Fram PH3387A or the AC Delco PF47 that is recommended for this engine, but I just wanted to double-check. I've used the over-size filter on the 2003 Malibu I maintain, but the filter is higher up and out of the way of any potential debris hitting it. Worst case scenario, I'll just use them on the Malibu but I'd rather use them on the Firebird since they're fairly expensive filters. Any help would be greatly appreciated!
Derek
Derek
