Headlight housings installed, adjustment pics
Northern Kentucky
Follow up to this thread
http://www.bobistheoilguy.com/forums/ubb...ng_#Post3364821
Here are some pictures of my new housings. I was surprised that the assembly came with everything including all bulbs and dust covers. I also noticed the wires are actually thicker than my oem housing. The only change I made so far is putting in the Sylvania silverstar Ultra regular bulbs. The bulbs that came with the housing all appear to be no name standard bulbs.
Two smaller boxes that came out of the large box
Both new ones out of the box
Old vs new
Out of the box regular lights were aimed horribly
Out of the box brights
First try adjustment
First try adjustment brights
After taking a drive and realizing that my initial aim was still bad
Same aim of brights
A few points I left out. I installed two new housings, a noted in the previous thread but not here. All the pictures are taken with me standing outside the drivers door behind the mirror area so I could switch the brights.
My parking lot is not level so I have a lot of work to do on aiming. The way it's sits which is hard to tell in the pictures is the cars in front of me are on a hill and my car is also on a slight grade.
I did find a gas station with a wall to aim at but unfortunately it wasn't flat either. Also my trunk in loaded pretty good so the aim should come down a little empty.
Also now that I think about it I should have taken a before picture.
