Yokohama AVID Acend 195/60R15. $190
by Sam_Julier
04/30/16 07:24 AM
Hate those adds that start with, "Lean 1 weird ...
by OneEyeJack
04/30/16 05:11 AM
How Much Olive Oil Do You Use?
by GrtArtiste
04/30/16 03:20 AM
Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
72 registered (2009Edge, AandPDan, AirgunSavant, Bandito440, barkingspider, BigCahuna, 7 invisible), 1345 Guests and 162 Spiders online.
57748 Members
66 Forums
248235 Topics
Page 8 of 21 < 1 2 ... 6 7 8 9 10 ... 20 21 >
#3367807 - 05/10/14 06:22 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Quest Offline
Loc: beaver land EH?
To me, this is just many rounds of the same thing from that very same poster over and over again.
Bertrand Russell's cosmic teapot, anyone?
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3368027 - 05/10/14 10:28 PM Re: What does Liqui-Moly CERATEC do? [Re: dave5358]
GaleHawkins Offline
Loc: Murray KY USA
Originally Posted By: dave5358
Originally Posted By: GaleHawkins
Our results are posted in this thread.
The thread link didn't come through. Would you post/re-post it? Thanks.
Look at my 25 April 2014 post in this thread or a copy of it below.
Copy
As Jtrans5 noted the dry start up is not really possible due to the hard coating. We are not talking build up that can measurably add to thickness. The place where the build up helps the most on the 325 Polaris aluminum head based on visual at tear down was the ceramic layer on the aluminum cam shaft bearings surface. That top aluminum bearing surface in any engine is as risk of a 'dry' start so if Ceratec coats those services how could it be a bad thing. Liqui Moly is not snake oil company I think most will agree.
Just from science I would not want competing coating chemicals trying to fight it out for bare metal parts at the same time. I could even see driving a few hundred miles on a new oil change before adding the Ceratec so the new detergent has cleaned the metal bearing surfaces very well.
Actually if anyone has some research on HOW and when one gets the coating build up when using something like Ceratec or Archoil AR 9300 I would like a link. I know from tearing down the 325 Polaris engine after 11 hours of idle time (had a chewed up crank from being ran without oil) and we just replaced the rod inserts and went with a used connecting rod. I had just learned about Ceratec and this blown ATV engine was just a perfect test bed.The parts cost was just $100 including the gasket kit.
I know without a doubt Ceratec works as Liquid Moly states it works. I know of no reason to not use it in a new engine because ceramic coated piston rings and pistons are sometimes placed in new engines.
If you have an engine that has rings that have to 'wear-in' due to friction you have a low quality finish on moving parts and must be using an old non-detergent stash of motor oil. smile
With that being said I would put 100-2000 miles on a new engine then change oil and add Ceratec to the new motor oil. This would let the moving parts like oil pump gears, gears, etc 'wear-in' and you could drain out any new engine metal.
#3389332 - 06/05/14 03:32 AM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
gman2304 Online   content
Loc: n.c.
Has anybody used the Ceratec in an air cooled engine?
#3389425 - 06/05/14 07:23 AM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
147_Grain Offline
Loc: USA
I add a little Cera Tec to my lawnmowers.
#3389707 - 06/05/14 12:03 PM Re: What does Liqui-Moly CERATEC do? [Re: gman2304]
Clevy Offline
Loc: Saskatoon canada
I'm using it in my Harley.
2006 Charger RT
Miles x 2 per oil filter
#3389806 - 06/05/14 02:01 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Loc: n.c.
Thanks guys, When I change the oil for the first time in my new to me 95 Electraglide I'm going to add the Ceratec. Clevy, in a 4 qt sump do you think 10 or 12 ozs would be about right? Thanks
#3389846 - 06/05/14 02:50 PM Re: What does Liqui-Moly CERATEC do? [Re: gman2304]
Clevy Offline
Hey gman
I think the can claims it's enough for 5 litres of oil,so if you've got 4 litres then 80% of the can should do.
From what I recall liqui-moly says that 6% of sump capacity is enough to be effective.
If anyone cares I pulled the plugs on my charger yesterday. I've had cera-tec in the sump for in excess of 15000 miles and the plugs are deposit free,which I feel is to be expected on an engine with 75000 miles.
And yesterday I took the plunge and changed the oil in the c3,as well as the plugs.
I put a can of cera-tec in with 5 litres of oil.
So let the testing begin. Oil was a mix of pp 5w-20 and castrol's 0w-40,a 50/50 mix to get near a 30 grade since I don't have any 5w-30 grades in my stash.
This far in the c3 I've noticed nothing but I've only got 100 miles on.
I'll start a thread to post any observations.
2006 Charger RT
#3389898 - 06/05/14 03:51 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Loc: n.c.
Clevy, how many miles on the Ceratec in the Harley?
#3389907 - 06/05/14 03:56 PM Re: What does Liqui-Moly CERATEC do? [Re: gman2304]
Clevy Offline
I put it in about 2000 miles after cams and big bore,so rough and tough about 8000 miles.
2006 Charger RT
#3390054 - 06/05/14 06:52 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Loc: n.c.
Clevy, How long do you run the initial fill with the Ceratec in the bike? Also how long should I go between changes? I also understand the filter should be of no less than a 15 micron. I'm leaning towards using the Valvoline 4t synthetic. Thanks
#3390061 - 06/05/14 07:04 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Clevy Offline
After the cam and big bore I did a couple of short runs with rotella,then I used motul 20w-50 on a 5000 mile run.
I suggest using the best oil you can and run it as long as you can to insure the plating effect is maximized.
The ceramic particles are minute,and the filter won't be able to catch them. From what I can recall from liqui-moly they are micron and sub-micron sized so nothing special is required.
I'd just use an oil that will last as long as possible. After that first run liqui-moly says 30000 miles before doing it again.
I've got no teardowns experience with cera-tec,but gale Hawkins does and his experience is pretty much exactly what liqui-moly says the stuff does.
I have torn down a 2v after using mos2 though,which is why I comment on those threads.
I've moly been using cera-tec for about a year,but I was using mos2 for many years and based on my experience with the products I've used I don't doubt a single word liqui-moly writes about their products.
I'm going to try mos2 after a wash out run of oil to see if there is any improvements to be had.
Ceratec leaves an extremely hard anti-wear layer behind so I'm wondering if a friction improvement can be measured after the ceramic layer is laid down.
Back on topic: just run the cera-tec as long as you can. I don't feel anything special needs to be done other than that.
Pm me if you've got anything specific. I'm glad to help if I can.
2006 Charger RT
#3391115 - 06/06/14 09:49 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Loc: n.c.
Changed the oil in my 2005 Chevy Avalanche 5.3 and added the Liqui-Moly Ceratec along with 5 and 3/4 qts of VWB 5w30. Leaving in the morning heading to Ocean Isle beach, NC for a week at the beach. The 200 mile drive tomorrow will give the Ceratec a chance to get blended good in the 166,000 mile 5.3. The Harley will be next when we return.
#3391962 - 06/08/14 07:18 AM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
vintageant Offline
Loc: Florida, USA
Is there a UOA posted anywhere where Liqui Moly CERATEC has been used?
1925 Alvis HDEO 15W40
1937 Alvis Speed 25 HDEO 15W40
1970 VW Peking to Paris Rally Beetle HDEO 15W40 w LM Ceratec
2003 Honda Accord dino 5W20
#3397759 - 06/14/14 10:34 PM Re: What does Liqui-Moly CERATEC do? [Re: gman2304]
GaleHawkins Offline
Loc: Murray KY USA
The 325 Polaris engine is air/oil cooled.
#3403908 - 06/22/14 04:24 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
dennishiip Offline
Loc: Ca
I have a brand new Ford Focus ST(turbocharged)rated at 250hp. When I reach 1500 miles, I will change the oil and add Ceratec. I emailed LM, and got an emphatic response to add the Ceratec ASAP. I'm waiting until first OC. I've had good results with MOS2, so I'm reasoning that the Ceratec with be even better for the new motor.
