Does the anti drain back valve material really make a significant difference?
I used to run Wix filters exclusively on my 360 magnum, until I found a parts store that was willing to give me a better deal on hastings Filters. For the past 2 oil changes I have ran a Hastings filter. I used to run a wix 51068 and now I run a hastings Lf196. The wix of course uses a silicone adbv and the hastings uses a nitrile adbv.
I live in Idaho where it gets 20-30 below in winter and winter is the longest season here, should I consider going back to wix because of the silicone adbv? I get charged 8 dollars and some change for the wix 51068 and I pay 5 dollars and some change running the hastings lf196. what do you guys think? My filter sits at an angle on my engine so drain back could be more of an issue then one that sits vertically.
