Hello all,
I recently did a brake job on a Chevy astro and replaced the wheel bearings while i was at it.
After the fact I found there is a 'proper' way to pack bearings, by sliding the bigger opening across your hand with a glob of grease in your palm.
I didn't use this technique.. I just spent a lot of time working grease into both sides of the bearing as well as down in the roller. I verified they were packed full because when I pushed more grease into either side.. it would puff out of the opposing side slightly..
Do I have anything to worry about since I didn't follow the 'proper' procedure? I could understand doing it if the bearings had old grease in them to force it out, but since these were new, old grease was not an issue.
Let me know your thoughts, thanks!
