O2 Sensor Voltage
by Falcon_LS
Today at 01:36 AM
Electrical shock at the grocery store
by Merkava_4
Yesterday at 11:42 PM
Another should I change my oil thread
by dan_erickson
Yesterday at 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
Yesterday at 08:48 PM
snapper blade control is stiff
by edwardh1
Yesterday at 08:44 PM
is my extension cord bad?
by motor_oil_madman
Yesterday at 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
Yesterday at 08:20 PM
Pineapple Margaritas
by sleddriver
Yesterday at 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
Yesterday at 07:56 PM
351W build with a flat tappet
by ssregal39
Yesterday at 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
Yesterday at 07:12 PM
Car's models of 1990 and now
by HTSS_TR
Yesterday at 07:02 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
13 registered (George7941, AdRock, dew, Chewie, gathermewool, A310), 517 Guests and 313 Spiders online.
58031 Members
66 Forums
249617 Topics
Page 6 of 6 < 1 2 3 4 5 6
#3378953 - 05/23/14 06:05 AM Re: Bugatti required oil [Re: fdcg27]
Shannow Offline
Loc: Oz
Cheers1
#3379513 - 05/23/14 07:04 PM Re: Bugatti required oil [Re: G-MAN]
bigjl Offline
Loc: London, England
I suspect Shannow was being a bit tongue in cheek
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3380248 - 05/24/14 07:26 PM Re: Bugatti required oil [Re: bigjl]
Shannow Offline
Loc: Oz
Actually, I started posting that way, then realised that one of my peeves in this country is that if a vehicle is fitted with certain speed rated tyres, it is illegal to downgrade, even 'though the fines for even running at 100MPH are over three grand...no-one in this country "needs" a tyre rated over 100MPH.
#3380260 - 05/24/14 08:01 PM Re: Bugatti required oil [Re: G-MAN]
d00df00d Offline
Loc: PA
I'm still trying to wrap my head around the fact that we're having a conversation about what's "necessary" for "most drivers" in a Bugatti Veyron.
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#3380555 - 05/25/14 07:09 AM Re: Bugatti required oil [Re: G-MAN]
Shannow Offline
Loc: Oz
Just shades of grey...no-one needs more than 5W-20 int heir Mustang for normal road use (and on the track, they don't need all the horsepower that they paid for either)...just shades of grey
#3380626 - 05/25/14 08:47 AM Re: Bugatti required oil [Re: Shannow]
SteveSRT8 Offline
Loc: Sunny Florida
Something quite often ignored here with our intense focus on absolutes (probably from all those darn engineers)....
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3380858 - 05/25/14 02:05 PM Re: Bugatti required oil [Re: G-MAN]
bigjl Offline
I don't see the point in using an oil such as 0w20 or 5w20 as it will be fine most of the time.
As then i would never be able to use all the performance of my vehicle.
Well only if i did a quick oil change to the proper specified oil to ensure the level of protection deemed appropriate by the company that designed and built it.
#3381843 - 05/26/14 10:30 PM Re: Bugatti required oil [Re: G-MAN]
72te27 Offline
Loc: Kentucky
Those of you scoffing at a hp rating being associated with a turbine engine are ignorant of the subject. A hp rating in an engine or motor is a mathematical, formulaic extraction based on torque and rpm. In an aircraft engine, thrust and aircraft speed, to put it simplistically, can be converted to hp. It is a straightforward mathematical formula. It is also more of an engineering construct than a "piloting" or aviating number. As a result, you don't often see it in aviation publications or articles, but you certainly see it in powerplant industry publications or articles and the like. It is not a 1:1 correlation, but thrust and hp numbers are often similar in a given high bypass turbine engine.
'72 Toyota Corolla 1.6
'03 Suburban 5.3
'05 Honda Accord 2.4
'08 Honda Accord 2.4
'11 Honda Accord Coupe 2.4
'11 Mazda 6 2.5
#3386228 - 06/01/14 11:54 AM Re: Bugatti required oil [Re: G-MAN]
adolan21 Offline
Loc: NH
This car can have a much higher top speed. The limiting factor is not the engine or aerodynamics but the tires themselves. People comparing this to an S2000 is just funny. Don't get me wrong, the S2000 had a fantastic motor but these two cars aren't even in the same league.
2010 VW GTI 2.0T- Mobil 1 0W40
2013 Honda Ruckus 50cc- Rotella 15W40, Rotella 10W30
2013 Triumph Street Triple- ?
#3412881 - 07/02/14 08:05 PM Re: Bugatti required oil [Re: G-MAN]
benjy Offline
Loc: pa
reading about ester oils some time ago + it was stated ONLY an ester oil can handle the heat of jet engines + the cost of the specially made ester oils used in jets is not changed is OUTRAGEOUS!!!
