Hey All, first post here. Been lurking for quite a while.
I've got an FR-S with the Aisin manual. It calls for a 75w-90 GL4. Shifting varies from car to car, but the general consensus is that 1-2 and a few other shifts often leave something to be desired, especially in the cold. Some have reported good results on MT-85, others like Motul Gear 3000 in 75w-90. Still others are swearing by Pentosin MTF2, which isn't even close to factory spec viscosity wise. Comments such as "The engineers were asleep when they specced the factory fill" seem pretty common. I'm unconvinced.
Is it really a good idea to run a fluid so far off from factory spec, even if it's a high quality fluid?
Secondly, I'd like to clarify specs, if I can, on the Ford Motorcraft "Honey". On the Miata forums, they're adamant it's a 75w90 equivalent GL4 made by Fuchs in Germany. Big Jim here says it's made by castrol and closer to a 10w40 diesel oil. This disagrees with the ford spec sheet here:
https://www.fcsdchemicalsandlubricants.c...ion%20Fluid.pdf
So unless that spec sheet is outdated I am very confused. If it is up to date, I am inclined to give this stuff a shot as it seems to hit all the points (GL4, right viscosity per my manual, specifically formulated to improve syncro operation etc). That plus it's glowing rep on other similar transmissions has me intrigued.
For the moment I've ordered some Motul as my track driving buddies swear by it for this car, but for daily driving I'm not convinced it's gonna have the cold performance I'd like.
Thanks!
Nathan
Thanks!
Nathan
