Hard Workers
by AirgunSavant
06/30/16 10:55 AM
which kind of vinegar to use?
by bmwjohn
06/30/16 10:53 AM
0% ethanol gas please
by yvon_la
06/30/16 10:17 AM
Motorex Legend 4T
by Junkie
06/30/16 09:56 AM
2ZR-FE Oil filter Comparison
by Tech819
06/30/16 09:45 AM
Andrews AFB
by AirgunSavant
06/30/16 08:55 AM
Luber Finer cut open
by Tech819
06/30/16 08:42 AM
Meguiars wax
by whip
06/30/16 08:02 AM
Weird problem with laptop. Thoughts?
by d00df00d
06/30/16 07:42 AM
Silverado 6.2L Fram TG 3 years and ~45,000 miles
by DriveHard
06/30/16 07:15 AM
Old bike, new engine -synth or dino oil?
by mr_blackstock
06/30/16 06:56 AM
F1 - 2016 Austrian Grand Prix
by gofast182
06/30/16 06:16 AM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
77 registered (AirgunSavant, 2015_PSD, AnthemBassMan, 01rangerxl, 1foxracing, 901Memphis, 7 invisible), 1859 Guests and 13 Spiders online.
58322 Members
66 Forums
251031 Topics
Page 2 of 3 < 1 2 3 >
#3360634 - 05/03/14 12:11 PM Re: Amsoil CVT Fluid [Re: Pablo]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I didn't know we are talking 2014. Thanks.
#3360642 - 05/03/14 12:29 PM Re: Amsoil CVT Fluid [Re: Pablo]
ProStreetCamaro Offline
Loc: MD
2013 pathfinder and jx35 uses the same cvt as the 2014 pathfinder and QX60 (QX60 is the new name for the JX35). So maybe amsoil just hasn't tested and verified that the new fluid will work correctly with these new cvt's? I would love to hear that the new amsoil cvt fluid meets or exceeds specs and wont void the warranty because I would switch it right away while it is still new.
Edited by ProStreetCamaro (05/03/14 12:32 PM)
#3360651 - 05/03/14 12:43 PM Re: Amsoil CVT Fluid [Re: Pablo]
Pablo Offline
I have asked Amsoil Tech.
Is Nissan officially saying NS-3 can be used in place of NS-2 in earlier NS-2 applications? Google provided no authoritative answer.
#3360671 - 05/03/14 01:25 PM Re: Amsoil CVT Fluid [Re: Pablo]
Loc: MD
That is a good question. I know her new car specs NS-3 but doesnt say anything about the previous NS-2
The manual says
" Use only Genuine NISSAN CVT Fluid NS-3. Using transmission fluid other than Genuine NISSAN CVT Fluid NS-3 will damage the CVT, which is not covered by the NISSAN new vehicle limited warranty."
Edited by ProStreetCamaro (05/03/14 01:35 PM)
#3361068 - 05/03/14 10:46 PM Re: Amsoil CVT Fluid [Re: Pablo]
The Critic Online   crying
Loc: Walnut Creek, CA
Originally Posted By: The Critic
Does it at least match the same color as the OEM fluid?
You do know that oil color is from an oil soluble dye? Color doesn't matter.
Until it is warranty time then it raises a red flag. If it matched then they wouldn't think anything of it. The 2013+ pathfinder and infiniti JX35/QX60 both use a new cvt and tons of people are having shudder problems and nissan seems to not be able to figure out a fix for it. My wifes new QX60 only has around 400 miles on it. I thought about switching to the amsoil cvt but wont out of fear they will deny warranty if she develops the shudder problem.
If they deny warranty for using a correct aftermarket fluid, they will be in violation of USA law. Amsoil CVT will not in any way violate your warranty. Color does not matter.
I understand your automobile is a huge investment. I think this is why I would want something better than the Nissan NS-2.
The shudder is fluid related:
Quote:
In the JASO LVFA Anti-Shudder Durability Test, AMSOIL CVT Fluid lasted six times longer, translating into improved anti-shudder durability and reduced noise, vibration and harshness.
Typical Amsoil salesman speak.
Sure, the mfg may technically be in "violation" of the act, but good luck with escalating the matter with Nissan.
While you are busy fighting them on the issue, your vehicle is out of service and you are majorly inconvenienced.
The sad part is that if the person had simply left the ORIGINAL fluid in the transmission, there would've been no issue at all.
As usual, avoidance is generally the better strategy. And besides, there's nothing to suggest that better anti-shudder protection of the fluid will fix the issue...that is pure speculation on your part.
Edited by The Critic (05/03/14 10:47 PM)
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#3361073 - 05/03/14 10:50 PM Re: Amsoil CVT Fluid [Re: Miller88]
Originally Posted By: Miller88
Dealer markup maybe? I have heard of $400 CVT fluid changes at the dealer.
$400 for a fluid change, and they still won't go 100K miles without failing.
Says who?
My dealer charges $189 for a drain and refill. $400 is probably about right for a full flush, since the fluid costs $15-$20/qt and you need 15 quarts. The service is generally unnecessary though, since you need to check the CVT fluid deterioration value using the factory scan tool in order to determine the need for a fluid change...it is not uncommon for the fluid to be good for well over 100k.
The failure stories are way overblown. Sure, they may have been some issues with the early Murano trannys, but some of those CVT failures were attributed to leaking CVT fluid due to a bad seal between the tranny and the transfer case, causing fluid loss.
Nissan has stood behind the transmissions very well with the 10/120k warranty, and based on the sales and overall experiences reported with the mass-produced 07-12 Altima, the CVT has been very successful.
Edited by The Critic (05/03/14 10:51 PM)
#3361247 - 05/04/14 08:24 AM Re: Amsoil CVT Fluid [Re: The Critic]
Loc: MD
Says who?
The problem is the NEW CVT that came out in 2013 is having a ton of shudder problems.
#3361293 - 05/04/14 09:52 AM Re: Amsoil CVT Fluid [Re: ProStreetCamaro]
Pablo Offline
And frankly there were problems before that - that you and I know were mostly caused by the fluid itself.
When in doubt throw the salesman thing out there. I'm not pretending to be a know it all on this situation. But I do know one thing, for every one rare warranty delay situation, there are thousands of cases when the dealers immediately back down.
I'm not sure why you are so against seeking a better solution. I mean when you turn into Mr. Detail, I'm pretty sure you are not just following what the factory says. You've done nothing but disparage Amsoil, and the new CVT fluid when in reality you know nothing about it. Amsoil seeks a BETTER than solution. In both Engineering and real life avoidance is NOT always a better solution. In fact AVOIDANCE is sometimes the worst decision ever.
I would say much of the shudder is indeed caused by a low bidder inferior factory fluid. Why anyone would be satisfied with that as a internet armchair proposed solution seems seriously weak at best.
#3361716 - 05/04/14 06:42 PM Re: Amsoil CVT Fluid [Re: Pablo]
MolaKule Offline
Loc: Iowegia - USA
Quote:
Despite the wear comparison on the page, I am still a bit skeptical of this fluid given the wide range of applications that it is suitable for.
I think that the additive suppliers have this wide range fluid applicability down to a science, well that is really what is, science.
Quote:
CVTs live-and-die by the correct fluid -- the belts are HIGHLY dependent upon very specific frictional properties in order to survive.
Belts are dependent upon the correct Traction coefficient.
Quote:
The coefficient of traction is defined as the usable force for traction divided by the weight on the running gear (wheels, tracks etc.)[5][6] i.e.:
Usable Traction = Coefficient of Traction x Normal Force
Factors affecting coefficient of traction[edit]
Traction between two surfaces depends on several factors:
Material composition of each surface.
Macroscopic and microscopic shape (texture; macrotexture and microtexture)
Normal force pressing contact surfaces together.
Contaminants at the material boundary including lubricants and adhesives.
Relative motion of tractive surfaces - a sliding object (one in kinetic friction) has less traction than a non-sliding object (one...)
Check WIKI.
I just wish Amsoil would introduce a low viscosity (6.1 [email protected], 38 [email protected]) MTF.
If they want to know how to do it or need a consultant, I know a guy who can help. grin2
Edited by MolaKule (05/04/14 06:43 PM)
Due to recent setbacks, my beach body will be postponed for another year. As usual, your patience is appreciated. smile
#3361743 - 05/04/14 07:04 PM Re: Amsoil CVT Fluid [Re: Pablo]
buster Offline
Loc: NJ
The NS-3 fluid makes me wonder how similar/compatible they are. Subaru in particular isn't having any CVT issues at all. I wonder how their fluid compares to Nissan's NS-2 and NS-3?
Amsoil goes for the niche market, which makes sense for them. This is one fluid though I would probably not want to use. However, it's good there is the option if need be.
#3363611 - 05/06/14 05:11 PM Re: Amsoil CVT Fluid [Re: buster]
mcrn Offline
Loc: FL
I believe that the Subaru is using a chain CVT and not a belt?
#3363686 - 05/06/14 06:21 PM Re: Amsoil CVT Fluid [Re: Pablo]
buster Offline
Loc: NJ
^ correct.
#3363780 - 05/06/14 07:29 PM Re: Amsoil CVT Fluid [Re: Pablo]
Pablo Offline
Amsoil CVT is NOT recommended for nor has it been tested in NS-3 applications.
#3560354 - 12/09/14 09:15 AM Re: Amsoil CVT Fluid [Re: Pablo]
m4gician Offline
Loc: Toronto, Canada
Hey guys,
Found the link here: http://www.amsoil.com/shop/by-product/tr.../?code=CVTQT-EA
And i'll be using it in an NS-2 tranny in my nissan murano.
Any cheaper deals? Amazon and Ebay had nothing. Is there a wholesaler of choice that carries this stuff?
Does anyone in Canada carry this stuff? I've called a few local guys and they said no.
Favourite Oil so far: German Castrol Syntec 0w-30 (Made in Germany)
Currently Using:
Engine: Esso XD-3 0w-30
Transmission: Mobil 3309 - A/W Trans
#3560364 - 12/09/14 09:33 AM Re: Amsoil CVT Fluid [Re: m4gician]
IveBeenRued Offline
Loc: Virginia, USA
Just become a preferred member under Pablo (ZO# 515729). It will cost you $10 for 6 months and then you can buy the CVT fluid at wholesale prices. Just go to amsoil.com and click on the "Buy Wholesale" button on the top. Then click the green "Click here to Become a preferred customer" button. Add the 6 month trial for $10 to your cart and you will immediatly be able to price the CVT fluid at the wholesale prices. Here are the Canada shipping rates. When you check out you will be asked who referred you and just put ZO# 51572.
Edited by IveBeenRued (12/09/14 09:41 AM)
2013 Ford C-Max Energi|18,500 Miles
Valvoline Synpower 0W-20|Fram Ultra
2012 Subaru Impreza Sport Ltd|110,000 miles
Mobil 1 EP 0W-20|Fram Ultra
