Margarita with Diet Squirt
by Duffyjr
05/28/16 06:31 AM
Mobil 1 5w40 TDT 3 vehicles
by Sw296inchblue
05/28/16 05:03 AM
Cheap brake fluid tester working properly?
by LucasDK
05/28/16 04:00 AM
Help finding specific oil.
by Mickxalix
05/28/16 02:28 AM
Found at Walmart: STP Multipurpose Motor Treatment $1.50
by MrQuackers
05/28/16 01:36 AM
Mobil 1 5w50 now FS too
by BobFout
05/27/16 11:55 PM
Front brakes for 1991 GMC Sierra 2500
by sr17
05/27/16 11:35 PM
7200 Miles
by Yup
05/27/16 11:08 PM
Result; 5 additives tested in a lab
by DrAdmin
05/27/16 09:25 PM
What are advantages of rotation ?
by HTSS_TR
05/27/16 09:22 PM
Arthritic joints
by Eddie
05/27/16 08:55 PM
Trouble Installing Filter
by Astro_Guy
05/27/16 08:09 PM
troutwest66, AIRJAC3, bpete65, LEVY, Timmytimmy
58000 Registered Users
48 registered (BigCahuna, Bandito440, AirgunSavant, Astro14, A310, Al, 3 invisible), 898 Guests and 312 Spiders online.
58000 Members
66 Forums
249512 Topics
#3361096 - 05/03/14 11:28 PM tests and case studies of archoil
boxcartommie22 Offline
Loc: moutain country
2001 Lincoln Conti,RL,K&N,SS Filter,Lubegard,Archoil
2007 Grand Marquis,RL,K&N,SS Filter,Lubegard,Archoil
2010 Raptor,RL,SS Filter,Lubegard,Archoil
#3361159 - 05/04/14 03:01 AM Re: tests and case studies of archoil [Re: boxcartommie22]
Shannow Online   content
Loc: Oz
For starters, they mis-apply the carbon mass balance procedure to running an engine at fast idle, under no load (well the differential of the exhaust stack, but that's the total load.
The mentioning of the nobel prize in chemistry has SFA to do with using organometallic compounds as a fuel catalyst, but two geezers who independently mapped out the structure of ferrocene, and worked out means of making it...but it makes it look/sound as though the nobel prize was for their snake oil.
And amazingly, it's BOTH a cetane improver and Octane enhancer.
As per the other thread, I've played with organometalic adds, thinking that the literature supplied demonstrated something...never once have I had positive effect (funny coloured sparkplugs not being either a positive or a negative).
OP in the other thread claimed instant results, while Archoil claim either thousands of hours, or miles are needed to "condition" the vehicle.
#3361162 - 05/04/14 03:42 AM Re: tests and case studies of archoil [Re: boxcartommie22]
Loc: Oz
And in recent years, (last 3) I've run dozens of tanks of this
http://image2.jcwstatics.com/documents/MaterialSafetyDataSheet_2011.pdf
Same active ingredient, with absolutely nothing happening.
#3361163 - 05/04/14 03:57 AM Re: tests and case studies of archoil [Re: boxcartommie22]
Clevy Offline
Loc: Saskatoon canada
Thanks Shannow
I didn't even bother going to the link. Marketing fluff cleverly worded so the reader is left to interpret how they see fit.
How exactly is a fuel system "conditioned"?
It's either clean or it isn't right?
Or what am I missing?
2006 Charger RT
Miles x 2 per oil filter
#3361166 - 05/04/14 04:16 AM Re: tests and case studies of archoil [Re: boxcartommie22]
Loc: Oz
Clevy, I've used this one as well...it's a better read, in that it tries to explain as opposed to baffle.
http://fpc1.com/sci_ferrocene.php
Interesting they claim that the studies show the octane enhancer part, but state that this is detrimental to diesels, and reduces fuel economy by the same mechanism...can't have both.
I can vouch for the red sparkplugs in another catalyst I used (Holt's Redkote, back in the early '90s)...interesting that the iron oxide produced by the combustion could be abrasive to valve guides... :doh: ...didn't think of that when I was running it.
#3361498 - 05/04/14 02:40 PM Re: tests and case studies of archoil [Re: Shannow]
simple_simon Offline
Loc: Indianapolis, IN
The OP hasn't the slightest idea how a modern IC engine works though as witnessed by the ridiculous hand-on-the-manifold test.
#3361797 - 05/04/14 07:51 PM Re: tests and case studies of archoil [Re: boxcartommie22]
silverrat Offline
Loc: Ontario
OP has been an additive junkie on this board for over 10 years, so his mind is well made up.
I just found it odd that the first PDF I clicked on had these mistakes
https://www.argreensupplies.com/uploads/Test_case_DCCG_Volvo-_Penta_revised.pdf
"Project: Reduction wear on Volvo- Penta Engines and stern drives
Started September 2012
Ended June 2012
ok.....
"Low speed towing is much of the included in their daily workload."
03 Civic Si(R) - Assembled in Swindon, England
Long Live the Manual Transmission drive
