How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
06/27/16 09:41 PM
Carpet cleaning methods.
by Run
06/27/16 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
06/27/16 09:26 PM
Emtrac Plus Battery
by Tapan
06/27/16 09:25 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
22 registered (edhackett, car51, Bill_G, bbhero, ac_tc, 1 invisible), 709 Guests and 11 Spiders online.
58295 Members
66 Forums
250917 Topics
#3360007 - 05/02/14 05:23 PM Petro-Canada Duron Syn|0w30|7386km(4589m)|G6 3.5L
cp3 Offline
Loc: Kitchener, Ontario, Canada
This run was for about 9 months, mostly short trips and idling. I'm not sure how many times I reset the OLM but it was at least 3, the last being the week it was changed. I did try to get it out for a run at least once a month. I don't know what the future holds as my wife's work schedule is unknown. It will see a daily run for a few months but after that we don't know.
FILTER
- Mobil 1 M1-101
USAGE
- About 5% highway
NOTES
- Cold winter, plugged it in several times this year
- Filter ran for 2 OCIs (about 14000km)
- Analysis done by Toromont/Caterpilar
Code:
                                                          VOA
     DATE:   04/18    01/13    10/12    7/12     3/12     1/12
      OIL:   PC       CATERHAM CATERHAM CATERHAM PC SS    PC SS
             DURON    BLEND    BLEND    BLEND
             0W30     60%/40%  60%/40%  65%/35%  0w30     0w30
   FILTER:   M1(2OCIS)BALDWIN  M1       WIX      FRAM TG
 TOTAL KM:   268829   254819   245317   234579   225992
KM ON OIL:   7386     9502     10738    8587     5742
      OLM:   3CYCLES  -42%     3%       7%       5%
   TOP UP:   0.5      1.5      1        0        0
       Fe:   20       7        8        9        9        1
       Cr:   1        0        0        0        0        0
       Mo:   16       88       88       92       80       81
       Al:   7        2        2        1        1        1
       Cu:   8        3        5        4        2        0
       Pb:   10       4        13       26       2        1
       Sn:   1        0        0        0        1        1
       Ti:   0        0        0        0        0        0
       Ni:   1        0        0        0        0        0
       Ag:   0        0        0        0        0        0
       Si:   14       7        13       20       18       5
       Na:   18       10       20       34       25       4
        K:   4        1        2        0        0        1
       Zn:   1298     756      783      882      787      785
       Mg:   10       18       30       16       8        10
        P:   1044     771      770      881      836      797
       Ba:   0        0        0        0        0        0
        B:   4        0        0        0
       Ca:   2577     1961     2060     2158
       Mn:   1        60       54       51
        V:   0        0        0        0
     SOOT:   0        0        0        0        0        0
     SULF:   32       35       37       34       21       15
     OXID:   22       34       36       34       13       9
     NITR:   15       13       14       13       11       5
  VIS CST:   10.41    10.59    9.72     9.91     9.19     11.48
      TBN:   5.0      6.0      5.5      4.5      1.5      7.50
  COOLANT:   NEG      NEG      NEG      NEG      NEG      NEG
     FUEL:   NEG      <1%      <1%      <1%      <1%      NEG
    WATER:   NEG      NEG      NEG      NEG      NEG      NEG
Edited by dnewton3 (05/04/14 07:04 AM)
Edit Reason: updated at OP request
Dodge Charger|Pennzoil Platinum 5w20|Mopar MO-744
Pontiac G6 GT|Mobil 1 0w40|Mobil 1 M1-101
#3360059 - 05/02/14 06:36 PM Re: Petro-Canada Duron Syn|0w30|7386km(4589m)|G6 3.5L [Re: cp3]
MobilinHyundia Offline
Loc: Ontario, Canada
Caterham blend is the way to go!
Much better results.
2009 Sonata GL 2.4L (201 000km)-AMSOIL 0W20 ,FRAM ULRA oil filter
2009 Sonata LTD 2.4L (132 000km)AMSOIL 5W20, Amsoil filter
24 000km oci so far
#3360077 - 05/02/14 06:55 PM Re: Petro-Canada Duron Syn|0w30|7386km(4589m)|G6 3.5L [Re: cp3]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
The higher Fe could be due to a lot of short trips over the winter. And we did have an especially brutal winter.
I think Duron 0W-30 is a decent oil but it does shear a lot which is probably a good thing in the G6.
BTW, are you really running M1 0W-40 straight this time?
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3360486 - 05/03/14 07:41 AM Re: Petro-Canada Duron Syn|0w30|7386km(4589m)|G6 3.5L [Re: cp3]
cp3 Offline
With the completely different usage, I don't think the results are directly comparable. I can't say I am disappointed with the Duron with how tough this OCI was.
And yes Caterham, I am running straight 0w40 LOL
Actually, with her driving routine being closer to what it used to be for a few months I'm interested to see how much oil it uses. The usage was down on the Duron but again with different driving schedule. I am curious if the thicker oil is helping that.
#3360592 - 05/03/14 10:38 AM Re: Petro-Canada Duron Syn|0w30|7386km(4589m)|G6 3.5L [Re: cp3]
CATERHAM Offline
But you don't have an oil consumption issue at all.
Averaging a pint of top oil in 7,500 kms is nothing.
So you're trying a grade heavier than required oil (with all the associated disadvantages) as an experiment on an engine with normal oil usage?
Are you trying to drop the oil consumption to zero that you had with the 65/35 CAT blend and PC SS?
Even for the sake of argument you do have lower oil consumption with the 40 grade, is it worth it?
I usually council those with 2-3 times your oil consumption to stick with the specified grade as long as the engine is still running well with no plug fouling or tail pipe smoke (you usually need to be burning more than a liter in 1,000 miles for that to occur).
The disadvantages of the heavier oil aren't worth what is usually only a marginal reduction in oil consumption.
#3360758 - 05/03/14 03:54 PM Re: Petro-Canada Duron Syn|0w30|7386km(4589m)|G6 3.5L [Re: cp3]
cp3 Offline
No, all of that is way more thought than I put into it!
It was on sale, I grabbed it thinking I could blend it or just run it. When it came time to change it, I had not given it any more thought so I poured it in.
I'll likely just go back to straight PP or M1 next time. Probably lean more toward PP as it seems to get a bit better sale than M1.
Of course this is all subject to change...
