Mystery electrical connector
Ontario, Canada
Just bought a used 2004 Grand Prix GT. Changed the air filter and saw this connector was unplugged. The problem is I can't find anywhere it would plug into. Any help or knowledge would be appreciated. The car seems to be running fine.
Mystery connector
Does yours have a Transmission temp? Mine is hooked up. That is the only thing I can think it can be. I suppose it could be for the Tap shift as well.
I have an 04 GTP Comp G.
The trans temp is a possibility. I'll check that out tomorrow.
The connection should be visible though right? Unless it's down under the trans dipstick.
Trans Temp
EGR
There is also on for the brake reservoir.
Clean your stuff man!!
I went out an looked real close. Does your car have Magnasteer?
I don't think the Normal GTs do.
My plug, after crawling under it, goes directly to the steering rack.
Apparently it was only available on the COMP G
