Let me start off with the facts:
- Alignment has been checked, is perfect.
- Drives completely straight, no odd pulling right or left.
- Newish tires
- New front end control arm assemblies
- New sway bar end links and bushings (or something like that)
- Hit a curb hard in the ice back in December. Alignment check, new tires, etc was after.
Now for the problem. When driving straight, the steering wheel is just slightly off center to the left. So if I line up the wheel perfectly straight, the car just ever so slightly goes right. I think this probably happened from hitting the curb in an ice storm.
questions:
1) It doesn't bother me too much. I'm probably OK leaving it alone. Any reason to fix it?
2) What would the culprit? What part likely needs replaced or adjusted?
Thanks.
- Newish tires
questions:
Thanks.
