Check out the head off my extreme oil burner Honda
by Gasbuggy
02/08/16 01:31 AM
Unused Bosch 3313 cartridge
by Run
02/07/16 11:14 PM
David Fry in his own words
by Merkava_4
02/07/16 11:02 PM
Trans Pacific Partnership
by Merkava_4
02/07/16 09:57 PM
Schaeffer 711 10w30 Detroit 60 12.7
by TiredTrucker
02/07/16 09:17 PM
2012 Mazdaspeed3 transaxle 36k OCI 75W80
by MD1032
02/07/16 09:13 PM
Ford announces new assembly plant in Mexico.
by mrsilv04
02/07/16 09:10 PM
Guy with a cart full of Euro 5W40
by ledslinger
02/07/16 08:51 PM
Ever wonder how the new Camaro is made?
by BobsArmory
02/07/16 08:43 PM
Credit Card Reader 4 Smart Phone-Small Business
by crazyoildude
02/07/16 08:16 PM
talent doesn't pay like it used to.
by motor_oil_madman
02/07/16 07:46 PM
Disappointed with Accord after one Salt Exposure
by JHZR2
02/07/16 06:58 PM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
27 registered (citationxeleven, Black, chrisri, akela, A1O, Axe Man, 2 invisible), 499 Guests and 199 Spiders online.
56850 Members
66 Forums
244398 Topics
Page 2 of 2 < 1 2
#3066278 - 07/15/13 04:54 PM Re: Duece and a half [Re: ridgerunner]
2cool Offline
Loc: Delaware
The engines in the olde Truck, 2 1/2 ton, 6X6, M-48, were compression-ignition engines designed by M.A.N. (Machinen fabrik von Augusburg und Nuernberg) built under license for the Army by Mack, Continental, White, and Hercules. The pump was a Bosch single piston distributor type, where the fuel lines from the pump to the injectors looked for all the world like reallly long spark plug cables. As the fuel entered the pump, it went through the Fuel Density Compensator. The density of the fuel would cause an adjustment of the quantity of the fuel injected, and change the injection timing. The theory was that the denser the fuel, the more energy. The denser the fuel, the more time it would take to burn.
IIRC, the Technical Manual called for 1 Qt. SAE 10 oil per 10 gallons of gasoline, just to lube the pump. It would get much lower mileage on gas, but it would go. I believe that even with a turbo, the output was 130 hp. But then the Army only planned on it going 35 mph in line-haul style operations.
#3358955 - 05/01/14 02:42 PM Re: Duece and a half [Re: ridgerunner]
ironman_gq Offline
Loc: MN
The old ones would run on just about anything because the injection systems were a lot more robust and simple. The old injectors were just a poppet valve with a nozzle on one side, it fired once per compression cycle and didn't need to be too terribly precise in metering fuel. Same with the pumps, they ran at a couple thousand psi at most, The new fuel systems on these trucks are using electronically fired injectors that can fire 4-5 times per cycle and pumps that operate at 30 thousand psi. To do that everything must have very precise tolerances, a change in fuel viscosity or a little debris in the fuel and the whole thing falls apart and parts get damaged.
Page 2 of 2 < 1 2
