Delo 400 for transmissions?
by Jabbo
08/30/16 04:04 AM
ATF: Dexcon III?
by Jabbo
08/30/16 03:59 AM
List an oil Additive you'd use / No Comments
by SuperDave456
08/30/16 02:33 AM
Driving style doesn't change mpg?
by Nick1994
08/30/16 12:30 AM
Autozone 20% off + free shipping
by jmaster
08/30/16 12:20 AM
Beginners guide to external ATF filters?
by buck91
08/29/16 11:27 PM
Good ADBV filter?
by asand1
08/29/16 11:18 PM
my brigs hates synthetic
by meborder
08/29/16 10:39 PM
Butcher factory cooler lines?
by buck91
08/29/16 09:47 PM
Grease for marine davit crane
by davebe
08/29/16 09:10 PM
2016 Traverse, which oil would you use?
by chevman4life
08/29/16 09:08 PM
acclimating to heat - tips, please
by pandus13
08/29/16 08:53 PM
davebe, Logos, alphanumeric, koidragon1980, iliveonnitro
58961 Registered Users
18 registered (dec219644, EchoTech1945, Farmer, dlundblad, eljefino, CaspianM), 605 Guests and 8 Spiders online.
58961 Members
66 Forums
253757 Topics
#3358414 - 05/01/14 06:07 AM 2011 TDi wagon
Sonataman Offline
Loc: Ga
Friend has one and swears the service techs tell him to run only the recommended oil, Castrol 5w30LL, and that they can tell if a customer runs anything else.
I'm not educated on what his car needs for oil, but I do know many good oils are out there for diesels.
I did look at some UOA's where as soon as people had dropped from 10k to 5k intervals the wear metals were drastically reduced.
What oils can he use?
Thanks.
2011 Hyundai Sonata
1994 KLX686
2004 Ninja 250
#3358455 - 05/01/14 07:21 AM Re: 2011 TDi wagon [Re: Sonataman]
TTK Offline
Loc: TN
Yes, but was the wear sum of two 5K intervals drastically less than one 10K?
2010 Volvo V70-3.2
Current Fill:Mobil 1 AFE 0w-30
2014 Subaru Forester, 0w-20 Castrol Magnatec
2001 Chevrolet Prism
NAPA Synthetic 5w-30
#3358469 - 05/01/14 07:38 AM Re: 2011 TDi wagon [Re: Sonataman]
Quattro Pete Offline
Loc: Great Lakes
Any oil meeting VW 504.00/507.00 spec. For example, M1 ESP 5w-30.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3358474 - 05/01/14 07:52 AM Re: 2011 TDi wagon [Re: Sonataman]
scurvy Offline
Loc: Chicago IL USA
crackmeup
My experience with VW disservice technicians is that they have told me lots of things, very few of which have any bearing on truth or reality.
As QP said, to maintain warranty any oils meeting VW 507.00 spec. If it were my common rail TDI, I would personally run MB 229.51 oils such as Mobil 1 ESP Formula M 5W-40. Common sense dictates whatever he runs should be DPF friendly regardless if he goes with something that will satisfy warranty requirements or otherwise.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#3358478 - 05/01/14 07:57 AM Re: 2011 TDi wagon [Re: Sonataman]
SF0059 Offline
Loc: Lynchburg, VA, USA
This list is a little outdated but it will help:
http://www.my-gti.com/2540
2014 Honda Odyssey EX-L/RES: 46K mi, M1 0w-40 & FU
2013 Toyota RAV4 Limited AWD: 53K mi, M1 EP 0W-20 & 0w40 & FU XG9972
#3358525 - 05/01/14 09:12 AM Re: 2011 TDi wagon [Re: Sonataman]
Volvohead Offline
Loc: SE Pa
Probably what they meant to say is that they can tell if a non-507.00 oil has been used. And they would be right about that.
Any 507 oil will be fine. I like M1 ESP in ours. We've also run the dealer Castrol early on. Both are good. Both meet warranty.
If under warranty, it must be 507.00 oil in the CR engines. Once out of warranty, you can play with the other low-SAPS varieties. Check with the TDI groups.
Be happy they knew that much. Your dealer is likely smarter than most. Mine overfilled ours with bulk tank 502 oil the first time, requiring a towback.
#3358537 - 05/01/14 09:35 AM Re: 2011 TDi wagon [Re: scurvy]
UG_Passat Offline
Loc: NJ
ESP 5w30 also has 229.51 approval.
oddly enough, ESP Formula M 5w40 was discontinued in Europe, which the ESP 5w30 replaced
