It seems like to me that I might have a failing brake booster in my 2004 Silverado (81,000 miles).
It started late in the winter, with an occasional stiff pedal. Now it happens more often, stiff pedal that even will even make a creaky noise as I press on the pedal harder.
I'm not hearing any hissing from a vacuum leak, as I kind of expected that I would, just a stiffer than normal pedal, and the creaking noise.
I do have a bad habit of having my foot on the brake pedal as I get out of the truck, and pushing on the pedal to "ooomph" myself out of the seat. I was involved in a wreck in 2009 that involved extended physical therapy, and doing this has turned into a bad habit.
I would assume that this is probably not helping the booster in any way, and may have shortened its life.
What should I be looking for or considering here?
