Originally Posted By: buster
No PDS
XOM MSDS (shows Pour Point as -17F)
Quote:
IMPORTANT HEALTH, SAFETY, AND ENVIRONMENTAL INFORMATION
Relative Density (at 15 °C): 0.851
Flash Point [Method]: 219°C (426°F) [ASTM D-92]
Flammable Limits (Approximate volume % in air): LEL: 0.9 UEL: 7.0
Autoignition Temperature: N/D
Boiling Point / Range: > 316°C (600°F)
Vapor Density (Air = 1): > 2 at 101 kPa
Vapor Pressure: < 0.013 kPa (0.1 mm Hg) at 20 °C
Evaporation Rate (n-butyl acetate = 1): N/D
pH: N/A
Log Pow (n-Octanol/Water Partition Coefficient): > 3.5
Solubility in Water: Negligible
Viscosity: 36.1 cSt (36.1 mm2/sec) at 40 °C | 8.5 cSt (8.5 mm2/sec) at 100°C
Oxidizing Properties: See Hazards Identification Section.
OTHER INFORMATION
Freezing Point: N/D
Melting Point: N/A
Pour Point: -27°C (
-17°F)
DMSO Extract (mineral oil only), IP-346: < 3 %wt
No specs known other than API SN/GF-5 and Toyota recommends it.
VOA/UOA's are available.
Wait, a pour point of -17...is this not HORRIBLE? or am I missing something? Just bought 5 quarts for my next oil change on the Accord (not that it matters here in FL).
