Getting hurt at work
by ram_man
08/28/16 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
28 registered (1foxracing, BrianF, BobsArmory, Bottom_Feeder, bmod305, 2004tdigls, 3 invisible), 669 Guests and 33 Spiders online.
58943 Members
66 Forums
253658 Topics
#3354759 - 04/27/14 03:37 PM Fluid Change News for VAG DSG Owners.
Volvohead Offline
Loc: SE Pa
For those with DSG boxes, the prevailing wisdom is that the vehicle must be perfectly level for all drain-outs, regardless of refill method. This seems to follow the particular concern regarding the fluid level sensitivity of these boxes (+/- .2L tolerance, and factory procedure snorkel-based fill and temperature level adjustments). DIY owners typically jack all four corners for the DSG service without question for fear of somehow offending the DSG gods.
As I found zero information elsewhere where top-fills are performed (including all the VW/Audi fora), I will post this here, for the VAG/DSG world at large:
For top-fill DSG fluid changes, you do NOT need to keep the vehicle level. Ramping up the front end (within reason) should allow a full and exact factory drain-out.
We did one yesterday on a set of standard height front ramps. Exactly 4.5L drained out. Refilled with 4.6L from the top (+0.1L for filter), slapped on a new filter, re-calibrated the box with VAG-COM, and it shifts beautifully.
#3355560 - 04/28/14 11:59 AM Re: Fluid Change News for VAG DSG Owners. [Re: Volvohead]
Thermo1223 Offline
Loc: Easton, PA
Just like when I had my 09A, people were so scared about measuring and refilling the exact amount.
If the transmission was that finicky the dealers would have killed loads of them in short order because they are not good at what they do either.
2004 - Jetta Wagon TDI - Gone
2009 - Subaru Forester XT - 4AT 5k OCI
2013 - Ford Fiesta Slick Party Hatch Edition
