Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
35 registered (Blkstanger, DemoFly, david_ES2, dave1251, bbhero, 3 invisible), 843 Guests and 33 Spiders online.
58943 Members
66 Forums
253657 Topics
#3354951 - 04/27/14 07:13 PM [Cut Open] Performax PO-37 4,314 miles
Texan4Life Offline
Loc: Texas
From the 06 altima 3.5L. 4,300 miles, 2 months, with Maxlife 10w-40.
http://i58.tinypic.com/bikk91.jpg
http://i61.tinypic.com/29liwwy.jpg
http://i61.tinypic.com/vsnu51.jpg
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#3354963 - 04/27/14 07:24 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Texan4Life]
Jarlaxle Offline
Loc: New England
Who makes/sells Performax?
1979 Coupe de Ville, 542 stroker, 15W-40 Super Tech, Delco
2011 Crown Vic P71, 5W-20 Valvoline NextGen, Purolator
2012 Suzuki AN400A, 10W-40 ST, Delco
#3354974 - 04/27/14 07:31 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Texan4Life]
gregk24 Offline
Loc: FL, USA
Why 10w40 in an Altima?
2012 Honda Accord EX-L
Taffeta White - Ivory
40,xxx miles
PPPP 0w20 / Fram Ultra
#3354980 - 04/27/14 07:34 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Jarlaxle]
ZeeOSix Offline
Loc: PNW
Base plate looks a lot like a Purolator. What's the bypass valve look like?
A filter's brand name doesn't matter ... what's inside does.
#3355007 - 04/27/14 07:50 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: gregk24]
Merkava_4 Offline
Loc: Clovis, CA
+1 That's an inappropriate viscosity grade for your application. spank
#3355010 - 04/27/14 07:50 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Texan4Life]
motts Offline
Loc: ny
It's marketed by SHELL
#3355011 - 04/27/14 07:50 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Jarlaxle]
Texan4Life Offline
Loc: Texas
It what was on sale :P
My guess is Purolator. These were given to me by my BIL who used to work at a lube shop.
I tossed the used one already.. maybe these will help...
http://i61.tinypic.com/1zp47ia.jpg
http://i59.tinypic.com/1htelg.jpg
http://i58.tinypic.com/2qdz7eo.jpg
#3355127 - 04/27/14 09:38 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: gregk24]
Padawan Offline
Loc: NJ
Why not?
The owners manual specifically states that 10W-40 is acceptable when ambient temperature is above 0 degrees Fahrenheit.
Not sure why some folks would state it's "inappropriate" for the application.
#3355130 - 04/27/14 09:39 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Texan4Life]
Stang40 Offline
Loc: SC, USA
Yes, they're Purolator Classic clones for the most part, though some sizes are slightly smaller than their Puro counterparts....used by Jiffy Lube.
2007 Suzuki XL7
Pennzoil Gold 5w30 + Wix
1994 Mitsubishi Mighty Max
ST 5w30 + Wix
Amsoil MTG
Pennzoil 75w90
#3355136 - 04/27/14 09:44 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Texan4Life]
aquariuscsm Offline
Loc: South Texas,USA
40 wt is perfect in your VQ. Keep using it.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#3355139 - 04/27/14 09:47 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Texan4Life]
ZeeOSix Offline
Loc: PNW
If this one is build by Purolator, then why is the pleat spacing and V-spread so much better than on the actual Purolator brand filters? Probably built on a whole different machine line I would suspect(?).
#3355220 - 04/27/14 11:20 PM Re: [Cut Open] Performax PO-37 4,314 miles [Re: Texan4Life]
Sayjac Offline
Loc: The Old North State
No doubt a Purolator made for filter with another excellent result. It is the equivalent to the shorty L14612 of which iirc I've seen no reports of any tears in application posted here. Thus until proven otherwise this is completely line with what's been posted here on this application and it's variants. Based on the date code this one also made in Fayetteville at same plant as the Classic, P1, Bosch Premium, and Distance Plus. And likely most similar to in not the same as Pep Boys ProLine and other Puro made jobber filters.
Generally speaking and in my personal experience, the 14610/14612 tend to have straight uniform pleating, this is no exception.
Thanks for the pics.
