Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
Fllow the DOT's
by WyrTwister
04/29/16 07:23 PM
Auto Rx?
by coopns
04/29/16 06:54 PM
Rotella for 6.0L Gasser
by Joefuskie
04/29/16 04:40 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
27 registered (bbhero, Defiant1, Atesz792, Duffyjr, Blkstanger, bdcardinal, 1 invisible), 615 Guests and 132 Spiders online.
57748 Members
66 Forums
248232 Topics
Page 1 of 2 1 2 >
#3354775 - 04/27/14 03:52 PM Oil for a 2014 Honda Pilot
lockguy Offline
Loc: Arkansas
Just got the wifey a 2014 Pilot which uses 0w-20. When we bought it, we got a lifetime power-train warranty.
Still got factory fill but Im doing my research ahead of time. The Napa syn is on sale for $3.49/qt but Ive heard some people complain about shear and a slightly low add pack. On top of that, the maintenance minders can go a long long way before they tell you its time to change the oil. One guy at the dealer said he has seen 20k oci by the mm. not sure if i believe that but still.
would this be a good oil for the recommended honda oci or should i go with another syn like quakerstate.
Im not really interested in spending top dollar for the more high end oil.
2007 Honda Fit 275k
2014 Promaster 40K
2005 Chevy Astro Cargo 115k
2014 Honda Pilot 10k
#3354783 - 04/27/14 04:02 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
Eddie Offline
Loc: Florida, Cape Coral
I see no reason to not use a name brand oil such as QS,PP or MI.
CX5 Touring 2.5L :-)
#3354788 - 04/27/14 04:06 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
Nate1979 Online   content
Loc: Portland, OR
What does your lifetime warranty require?
2015 GMC Sierra 2500 6.0L Factory fill
2010 Subaru Forester 2.5X QSUD 5w-30 w/ Fram Ultra
#3354789 - 04/27/14 04:06 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
gregk24 Offline
Loc: FL, USA
PP, M1 AFE, VSP are all good OTC 0w20's. I would recommend TGMO 0w20 though, it is readily available at Toyota dealers and it is priced well. I use it in my Accord and get 5 quarts for under $30. Not sure if you know what TGMO is...if you do great! If not, then here you go..Its Toyotas own synthetic, manufactured by Exxon Mobil. It is one of the lightest (if not the lightest) 0w20 on start up, and it has a great add pack.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3354812 - 04/27/14 04:27 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
mclasser Offline
Loc: The Right Coast
I've used M1 and PU so far and my Pilot loves them both.
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
2002 Infiniti I35
#3354821 - 04/27/14 04:38 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
Falken Offline
Loc: Montreal, QC, Canada
Wow just noticed you have a 250K Honda Fit.
Is the Fit holding up well? No trans issues or anything?
I'd recommend Pennzoil Platinum 0W20 to honor the Warranty on the new Pilot.
Falken - Draftsperson
2010 Honda Fit DX-A in Black
Current Fill: Formula 1 Synthetic 5W20 SN, Wix 57356 Oil Filter, ATF DW-1
#3354830 - 04/27/14 04:50 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
A good synthetic 0W-20! LOL
All kidding aside. Assume VCM. Assume sludge. Any of the oils mentioned, I would still go into change mode at 20%.
Personally I would use Amsoil OE 0W-20 and pocket the savings.
#3354839 - 04/27/14 05:06 PM Re: Oil for a 2014 Honda Pilot [Re: Falken]
lockguy Offline
Loc: Arkansas
the Fit runs like the day I got it. Its probably the best buy Ive ever made. love that car. The last oil change I put half a can of mos2 to see if we could increase fuel efficiency any. Currently getting approx 31mi/gal. Used it in my transit and noticed 1-1.5 mi/gal increase.
We used M1 or PP up until around 200K. But I had started using Trop artic in my transit and using the eyeball test, the oil looked fantastic so we just started using that in the honda as well. Still no leaky gaskets or anything else. No tranny issues although we had someone replace the clutch and I don't think they got the flywheel resurfaced like they said they did so the clutch is a little funky. Other than that..bulletproof
2007 Honda Fit 275k
2014 Promaster 40K
#3354847 - 04/27/14 05:12 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
dave123 Offline
Loc: wi
M1EP 0w20 All day every day at WM $5.00qt
#3354857 - 04/27/14 05:22 PM Re: Oil for a 2014 Honda Pilot [Re: Nate1979]
lockguy Offline
Loc: Arkansas
Warranty just requires that i keep documentation of the oil changes and use the API certified oil in the correct grade, whatever the manual states. Not sure if it mentions GF-5 or not but I wouldn't use older GF anyway. I need to follow the maintenance minder unless i use something like M1 extended then I would need to make sure I keep track of mileage between oci.
I can also do the changes myself, which I do on my other vehicles, just keep receipts etc and document in the owners manual.
Thats why I was thinking about the napa syn, it meets spec and its cheap syn. I still wouldn't want a rough running car that they won't fix because its still running lol.
Considering I didn't see one person stick up for napa, I think ill go with a sopus or M1.
2007 Honda Fit 275k
2014 Promaster 40K
#3354860 - 04/27/14 05:26 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
lockguy Offline
Loc: Arkansas
I would totally use the trop artic if I could get 0w-20 at orscheln's for $1.99/qt like the 5w-20 and 5w-30 i get.
2007 Honda Fit 275k
2014 Promaster 40K
#3354879 - 04/27/14 05:53 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
crazyoildude Offline
Loc: New Jersey
my neighbor has a 2013... He has has alignment issues at 5000 miles the rear wheels looked bowed out.. How do yours look? Nice vehicle... Not too sure about that lifetime warranty though..
In Automotive class when i was a kid i had a shop teacher that always said ..Its Nice To Be Nice! That is one thing i always remembered..
#3354880 - 04/27/14 05:54 PM Re: Oil for a 2014 Honda Pilot [Re: dave123]
HTSS_TR Offline
Loc: Lake Forest, CA
Agreed. M1 EP 0W20 $25 5-qt jug at Walmart is a better buy with OLM downs to 0%.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3354912 - 04/27/14 06:28 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
Loc: Portland, OR
That sounds like a good lifetime warranty then. Most of them are not worth the paper they are on because they require all maintenance at the dealer.
#3355030 - 04/27/14 08:06 PM Re: Oil for a 2014 Honda Pilot [Re: lockguy]
lockguy Offline
Loc: Arkansas
we got the EX-L, really slick inside, all leather. msrp was around $38,500, we got it for $31,500. two dealers in our area, i just went back and forth between the two telling what the other offered. I did it until one gave up. the best offer also had the warranty.
Alignment looks fine but we only have 800 miles on it now. I wonder if he did something to cause that?
Edited by lockguy (04/27/14 08:07 PM)
2007 Honda Fit 275k
2014 Promaster 40K
Page 1 of 2 1 2 >
