Small 4 Cycle Engines, longevity tips
by henni
05/29/16 10:05 AM
Car won't star after new serpentine belt
by AlaninPA
05/29/16 09:06 AM
Was this sold by Costco?
by Vikas
05/29/16 09:03 AM
Gas or lithium-ion powered string trimmer?
by skyactiv
05/29/16 08:41 AM
Tire pressure question
by Tlhfirelion
05/29/16 07:18 AM
So I did an oil change but didn't change the filte
by Tlhfirelion
05/29/16 07:05 AM
Mixing Mobil 1 0w20 with 5w30
by doublebase
05/29/16 06:49 AM
Max Life @ Menards
by scusemez28
05/29/16 06:24 AM
Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Lowes charcoal sale
by Bandito440
05/28/16 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
05/28/16 10:10 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
80 registered (AIRJAC3, 901Memphis, 2015_PSD, AirgunSavant, 69GTX, 2004tdigls, 7 invisible), 1699 Guests and 136 Spiders online.
58013 Members
66 Forums
249553 Topics
#3354477 - 04/27/14 08:57 AM NOACK and dipstick correlation?
wemay Offline
Loc: South Florida
Is their a direct correlation between the two? In other words, if you notice oil loss/lower than max level on the dipstick, should you look for a lower NOACK oil (as one of many posible solutions)? Conversely, if your dipstick never shows lower levels, you're good?
Edited by wemay (04/27/14 08:59 AM)
16 Toyota Corolla LE 1.8L
13 Hyundai Santa Fe 2.0T
#3354485 - 04/27/14 09:06 AM Re: NOACK and dipstick correlation? [Re: wemay]
147_Grain Offline
Loc: USA
For newer vehicles, use of a higher quality synthetic oil tends to already have a lower NOACK and there's not much to worry about. Even newer engines use a little oil over time and this is normal.
Just check your fluids twice a month to get a handle on IF they need topping off. IF things are consistently OK, then a monthly check of their levels is fine.
In the long-run, maintenance with higher quality fluids and filters is more important than getting caught-up in the nitty gritty details (which can be fun to at least know about on occasion).
#3354488 - 04/27/14 09:09 AM Re: NOACK and dipstick correlation? [Re: wemay]
gregk24 Offline
Loc: FL, USA
In my opinion, if you are losing oil as seen on your dipstick, its either burning off or leaking. The NOACK is tested in high temperatures, so in all reality you will lose very little oil as a result of it evaporating due to a high NOACK.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3354491 - 04/27/14 09:12 AM Re: NOACK and dipstick correlation? [Re: gregk24]
Quattro Pete Offline
Loc: Great Lakes
+1
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3354495 - 04/27/14 09:14 AM Re: NOACK and dipstick correlation? [Re: wemay]
Hyde244 Offline
Loc: Ohio
NOACK is apart of the equation for oil loss, as it is the evaporation of the oil. However, burning oil or leaks in the seal are often more likely the reason for oil loss.
2007 Ford Focus ZX4 SES - 2.0L Duratec | 4F27E Auto | 92,000 miles
PU 5w20 | MC 910 | Castrol Mercon V
#3354504 - 04/27/14 09:30 AM Re: NOACK and dipstick correlation? [Re: wemay]
wemay Offline
Loc: South Florida
Ok thanks all. Just checking as a family member with a 2000 Honda Odyssey (100k miles) is having to put 2qts every 7500 miles. No leaks. MaxLife or GTX HM is the next step.
Edited by wemay (04/27/14 09:33 AM)
#3354549 - 04/27/14 11:00 AM Re: NOACK and dipstick correlation? [Re: wemay]
otis24 Offline
Loc: South Dakota
I add one qt every thousand miles, like clock work. Vehicle is a 2009 Chrysler T&C. They are known for oil usage. Hence, i will be doing 10k OCI's since i add so much oil. Currently using Mobil 1. Next change will be with old stock Pennz Ultra with lower NOACK to see if things improve. I will post here, but that will be a while!
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
2009 Chrysler T&C (85k, 3.8)
#3354566 - 04/27/14 11:32 AM Re: NOACK and dipstick correlation? [Re: Quattro Pete]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
+1
+2
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3354577 - 04/27/14 11:47 AM Re: NOACK and dipstick correlation? [Re: wemay]
jrustles Offline
Loc: Ontario, Canada
your question is a matter of volatility with oil leaving via the ventilation system vs slipping past the rings, valve seals, turbo seal etc.
You can't blame all oil loss on volatilization with so many other common modes of consumption to consider.
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3354818 - 04/27/14 04:33 PM Re: NOACK and dipstick correlation? [Re: wemay]
Shannow Offline
Loc: Oz
NOACK is designed to simulate the presence of oil in the piston ring belt, and the film on the cylinder wall exposed to combustion heat, which is a single source of oil consumption, amongst valve guide, genuine oil flow past rings, and of course leaks.
As such, it's not a dipstick correlation.
It's purpose is with regards to phosphourous volatility and cat life, not bulk oil boil-off...
#3354840 - 04/27/14 05:07 PM Re: NOACK and dipstick correlation? [Re: wemay]
wemay Offline
Loc: South Florida
Thank you all.
#3354869 - 04/27/14 05:45 PM Re: NOACK and dipstick correlation? [Re: wemay]
SilverC6 Offline
Loc: Southeast
More factors in oil use than NOACK.
Viscosity is probably a greater consideration.
Oil getting by the rings or slipping through valve guides is going to be worsened with thinner oil.
'04 Mazda RX8 5W30 Valv Synpwr
'10 &'11 Camry 5W-20 PU
'11 Landcruiser 5W20 PU
'13 BMW 550IX BMW 5W30
'08 BMW Z4M Coupe TWS 10W60
'13 BMW M6 BMW 5W30
