Ugly New Prius #2
by AirgunSavant
08/28/16 08:32 AM
Getting hurt at work
by ram_man
08/28/16 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
73 registered (4WD, 09_GXP, 2010Civic, 2015_PSD, 2009Edge, 2004tdigls, 5 invisible), 1290 Guests and 25 Spiders online.
58943 Members
66 Forums
253659 Topics
#3354291 - 04/26/14 11:06 PM Cut open, Mobil 1 M-107, 14K miles
jeffie7 Offline
Loc: MD, USA
Did an oil change on my friends car, had higher miles on the oil/filter so figured it would be a great filter to cut into.
Car, 2001 Corvette with 150K miles
Oil Royal Purple
Miles on filter 14,000
Car has had 4-5 Track days in those 14,000 miles
With Flash
With Flash
#3354311 - 04/26/14 11:33 PM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
GaleHawkins Offline
Loc: Murray KY USA
Looks like 14K may be a little long in your friend's case. Thanks for the photo.
#3354314 - 04/26/14 11:35 PM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
HTSS_TR Offline
Loc: Lake Forest, CA
Filter looks very good for 14k miles. If someone likes to reuse filter for 2 8-10k OCI then M1 Extended Performance filter will be able to do it.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3354358 - 04/27/14 04:06 AM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
TriboGeek Offline
Loc: CA, USA
Seems impressive to me, but what do I know. I just think its impressive that it is still holding up. How to know if it is at capacity though?
How much time was it installed for?
2010 Golf 2.0L TDI, Castrol SLX 5w30 Synth, factory filter
1989 Toyota AW11 MR2, 1.6L built 4AGE, 150WHP, M1 0w40, JDM Toyota filter (-10004)
#3354359 - 04/27/14 04:26 AM Re: Cut open, Mobil 1 M-107, 14K miles [Re: TriboGeek]
David1 Offline
Loc: USA, FLA
From Pics I have seen many Mobil 1 Oil Filters ** Not ALL ** have the same bypass set up as FRAM... but many do and as you can see from pic its A leaf spring at the bottom of the oil can with the bypass built in with another spring.
here is a pic
perhaps it might be a better plastic then FRAM and Im not saying the FRAM bypass is bad...
Im just making a point.
2002 Honda Accord V6 3.0 Automatic Trans 203000 Miles
Valvoline Maxx Life 5W30
Purolator BOSS Or HONDA Filtech A01s
#3354362 - 04/27/14 04:56 AM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
Char Baby Online   content
Loc: Western NY
This M1 filter look excellent to me! Nice straight pleats, and the media seems nice and thick/robust!
IDK about running any filter 14K miles as I have never tried it but, the filter still looks good. smile
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3354373 - 04/27/14 05:35 AM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
pbm Offline
Loc: New York
It looks pretty good for 14K.
Did he run the Royal Purple for 14K as well?
#3354560 - 04/27/14 11:16 AM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
GMBoy Offline
Loc: Texas
14k miles with 4 or 5 track days is excessive use on the oil. But the filter did well.
#3354611 - 04/27/14 12:28 PM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
TriboGeek Offline
Loc: CA, USA
I know M1 filters have different bypass designs depending on model. M1-209 has a "front end" bypass, like many Wix, using a spring. Avoids flowing oil across the dirty media in bypass mode.
Edited by TriboGeek (04/27/14 12:29 PM)
#3354707 - 04/27/14 02:34 PM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
jeffie7 Offline
Loc: MD, USA
No doubt it was an extended change even more so with the track days. But it is what it is. He knows it should have been changed sooner. We get a good sample of a filter out of it so that's always a good thing.
He said oil was not changed but he did add about a quart In top offs.
As for time, 7 months or so of driving. The other 5 were with the car sitting on jack stands since his coil over snapped. Had to wait for them to warranty the part. That took forever. Once the new part came in I installed it for him and did the oil while I was under the car.
So while it was a year. It sat without being run for almost half of that time.
Edited by jeffie7 (04/27/14 02:35 PM)
#3354806 - 04/27/14 04:23 PM Re: Cut open, Mobil 1 M-107, 14K miles [Re: jeffie7]
ZeeOSix Offline
Loc: PNW
Any idea what the Oil Life Monitor showed on the car at the many miles on the oil. The OLM system will take into account how the car is driven, so track days would have knocked off more oil life percentage than cruising down the highway at 60 MPH.
A filter's brand name doesn't matter ... what's inside does.
#3354809 - 04/27/14 04:25 PM Re: Cut open, Mobil 1 M-107, 14K miles [Re: TriboGeek]
ZeeOSix Offline
Loc: PNW
Just looking at it may not be an accurate way - unless of course it filled up with sludge, etc while being on a very dirty engine. The only accurate way to know would to be able to measure the delta-p across the filter in real time while being used on the car.
#3354813 - 04/27/14 04:28 PM Re: Cut open, Mobil 1 M-107, 14K miles [Re: David1]
ZeeOSix Offline
Loc: PNW
here is a pic
The "plastic" (high temperature nylon composite) in both filter brands is specified for the high temperature oil environment they are designed for.
There has never been any reports of "plastic" bypass valves that look defective after a filter cut-open.
