Fram Ultra Bypass Valve Spring Life
by Digital2k2
05/29/16 11:32 AM
CARQUEST Filters are now made by Purolator (pics)
by sir1900
05/29/16 11:03 AM
Small 4 Cycle Engines, longevity tips
by henni
05/29/16 10:05 AM
Car won't star after new serpentine belt
by AlaninPA
05/29/16 09:06 AM
Was this sold by Costco?
by Vikas
05/29/16 09:03 AM
Gas or lithium-ion powered string trimmer?
by skyactiv
05/29/16 08:41 AM
Tire pressure question
by Tlhfirelion
05/29/16 07:18 AM
So I did an oil change but didn't change the filte
by Tlhfirelion
05/29/16 07:05 AM
Mixing Mobil 1 0w20 with 5w30
by doublebase
05/29/16 06:49 AM
Max Life @ Menards
by scusemez28
05/29/16 06:24 AM
Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
75 registered (2015_PSD, aquariuscsm, AirgunSavant, AlaninPA, Al, AandPDan, 8 invisible), 1737 Guests and 121 Spiders online.
58013 Members
66 Forums
249555 Topics
#3353820 - 04/26/14 12:39 PM 0w-20 in a 2006 Civic?
trx250x92 Offline
Loc: Tri Cities, TN
Looking for opinions on whether or not my Civic in my sig would be a good candidate for 0w-20. No consumption/leaks. I know the 2012+ Civics with basically the same engine spec this oil. My only concern is the summer heat that is approaching soon.. mostly 80 days but some extremes of high 90s - low 100s at times. My driving is 75-80% highway and running 70 mph turning 3k rpm. Engine block has 50k miles and the head has 130k miles (block cracked and was replaced under warranty in 2009.) Been wanting to try the Napa synthetic while it's on sale.
Edited by trx250x92 (04/26/14 12:49 PM)
2006 Civic EX Coupe R18A1 - Castrol Edge 0w-20 & Wix 57356
1999 F-150 S-cab 4.6 4x4 - Valvoline Durablend 5w-20 & Motorcraft FL-820s
#3353828 - 04/26/14 12:58 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
Brybo86 Offline
Loc: Chicago, IL
130k? and no leaks? i'd stick with whatever u have been doing...
08 Honda Accord EX-L 2.4L RP 0w20 116k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 178k
95 Yamaha Jog
86 Kawasaki 454Ltd Valvoline 20w50 18k
#3353852 - 04/26/14 01:39 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
pbm Offline
Loc: New York
I'm sure the 0w20 would do fine if it's spec'd for 5w20.
I would use the 0w20 in the winter.
#3353866 - 04/26/14 01:58 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
Roob Offline
Loc: Ontario,Canada
The 2006 civic is specced to use 0w20. Pour it in and enjoy...
As far as the summer temp described is concerned, don't be.
0w20 will easily handle the engine temp and that is much hotter than the outside environment will get.
My recommendation is for TGMO, MGMO or HGMO GF-4 if you can get it..
2007 Accord Coupe 2.4 Vtec.
QSGB 5w20 with Fram TG
HDW1+ LG Platinum
Toyo Versado Noir-V
#3353875 - 04/26/14 02:11 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
901Memphis Offline
Loc: Northern Kentucky
TGMO or Mobil 1 AFE 0w20 would be a fine choice.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3353876 - 04/26/14 02:12 PM Re: 0w-20 in a 2006 Civic? [Re: Roob]
trx250x92 Offline
Loc: Tri Cities, TN
Did Honda change the spec on the 2006 Civics? Mine originally called for 5w-20. Forgot to mention that in my original post.
#3353889 - 04/26/14 02:27 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
Roob Offline
Loc: Ontario,Canada
Sorry, I should have put that in my reply.
Honda has back specced the civic to use 0w20.
The GX is still 5w20, the hybrid is 0w20, SI is 5w30.
Here's a link to the oil chart.
http://www.invergrovehonda.com/oil-application-chart.htm
HDW1+ LG Platinum
Toyo Versado Noir-V
#3353894 - 04/26/14 02:44 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
gregk24 Offline
Loc: FL, USA
It should have been back spec'd for 0w20. I would go with TGMO 0w20, it will love it.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3353974 - 04/26/14 04:48 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
fdcg27 Offline
Loc: OH
You could certainly use a 0W-20.
The question is why do you want to?
Not sure that you'll see any difference at all from a 5W-20.
I use 0W-20 in our '12 Accord since that's what Honda recommends and only a fool wants to fight the uphill battle over a warranty claim when using a grade other than what's recommended.
Nothing wrong with a 0W-20, but what's wrong with using the 5W-20 originally recommended for your engine?
You must not be all that picky about oil, since it appears that you're currently running a frankenblend.
Any 5W-20 syn would be an upgrade from what you're running now.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3354065 - 04/26/14 06:37 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
SLCraig Offline
Loc: London, ON, Canada
You can run 0w20 in that car no issues.
I ran it in my R18 and it ran just as well as any other 20w oil I tried. (Specifically I used M1 AFE)
2010 Civic SI sedan 6MT
Total Quartz 9000 | Wix 7356 | Pennzoil MTF
#3354073 - 04/26/14 06:43 PM Re: 0w-20 in a 2006 Civic? [Re: fdcg27]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
What's the difference between a typical 5W-20 and the Napa 0W-20 the OP wants to use? Almost nothing.
The only 0W-20s that would make a possible noticeable difference or if you simple want to get the maximum benefit of the 0W-20 grade you'll have to try one of the OEM oils such as TGMO or MGMO 0W-20.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3354105 - 04/26/14 07:18 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
Cooper Offline
Loc: Mid-West, USA
I use 0w20 year round.....same engine. Works great!
2012 Nissan Xterra
2014 Subaru Forester
PENNZOIL ULTRA PLATINUM
#3354167 - 04/26/14 08:39 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
tig1 Offline
Loc: Illinois
M1 0-20 holds up very well in temps we have here in Illinois which at times hits over 100F.
2007 Ford Fusion 181,000 miles
M1 0-20 AFE
2007 Ford Focus 154,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#3354336 - 04/27/14 12:50 AM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
trx250x92 Offline
Loc: Tri Cities, TN
I bought some Napa Syn 0w-20. I appreciate the input. Not really looking for any gains, I had just been wanting to try something different, and my frankenblend that I'm currently running is just leftovers from previous changes in our Hondas except for the lone qt of PP.
#3354960 - 04/27/14 07:21 PM Re: 0w-20 in a 2006 Civic? [Re: trx250x92]
Patman Offline
Loc: Oakville, Ontario
I've got the exact same car (2006 EX coupe) and have been running Mobil 1 0w20 in it for the past few years with excellent results! The oil analysis results show low wear and consumption is almost nothing (0.3 qt in 6000 miles for instance)
2005 Corvette (M1 5w30 & Fram Ultra)
2006 Civic EX Coupe (M1 0w20 & Fram Ultra)
2010 BMW 328i X-Drive (M1 0w40 & Mann filter)
