comparing wix 1334 vs 51182
Dunbar, WV USA
Part Number: 51334
UPC Number: 765809513341
Style: Spin-On Lube Filter
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Outer Diameter Bottom: Closed:
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
VS
Part Number: 51182
UPC Number: 765809511828
Type: Full Flow
Media: Paper
Height: 5.207
Outer Diameter Top: 3.66
By-Pass Valve Setting-PSI: 24
Burst Pressure-PSI: 350
Max Flow Rate: 7-9 GPM
How does the 1334 have a have a higher flow rate than the 51182(bigger) but they both have the same nominal micron rating?
The only way I'd ever go oversize is if the gasket sizes were exactly the same such as a Wix 51040 and 51036.
In my case it still seals. Look very closely.
EDIT: Wix 51040 and 51036 DONOT have the correct thread that you selected.
Not for you, but for me they do.
This thread isn't for you
LOL!
But when did you serve?
Originally Posted By: dlundblad
I'd be concerned about the higher bypass on the 51182.
but what about the lower bypass on the 51334?
What is the OEM filter's spec? I would take this comparison test a bit further and actually test the OEM filter from a few popular applications, just to give us more info about which filter to select.
It's also technically smaller from what I've calculated. I wonder how that is achieved...?
How about.
Part Number: 51324
UPC Number: 765809513242
Type: Full Flow
Media: Paper
Height: 4.354
Outer Diameter Top: 3.663
By-Pass Valve Setting-PSI: 16
IIRC, the OP mentioned in another thread that the 51334 was the OEM spec'd filter for his Honda van. Using a filter with more than double the spec'd bypass settings might starve the engine of oil in higher RPM situations.
The bypass setting on the larger one you originally posted is double the 1334, that's a deal breaker right there IMO. I tried that once and had rattle and running issues.
