Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
05/26/16 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
05/26/16 10:07 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
22 registered (cobra7279, bbhero, chrisri, Bandito440, 3 invisible), 474 Guests and 331 Spiders online.
57996 Members
66 Forums
249469 Topics
#3353000 - 04/25/14 03:13 PM Adding Lubro Moly Oil saver will increase grade?
Yannick Offline
Loc: Montreal,Quebec,Canada
Hi,
By adding one can of Lubro Moly Oil saver in 5liters of 10w30 , will change the grade to what approx? 15w40?
thks
#3353073 - 04/25/14 04:24 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
dave5358 Offline
Loc: North Bend
Originally Posted By: Yannick
Hi,
Liqui Moly Oil Saver (fka Lubro Moly Oil Saver) shouldn't change the grade at all. From the manufacturer's website, it says:
Regenerates rubber and plastic engine seals such as shaft seals and valve stem
seals and prevents oil stains under the vehicle. Counteracts oil dilution. Reduces
engine noise and oil consumption through piston rings and valve guides.
It swells rubber seals or at least makes them more pliable.
You may be thinking of Motor Honey or STP?
2006 Forester XT
2008 Corolla LE
#3353140 - 04/25/14 05:44 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
Falcon_LS Offline
Loc: Kuwait
Motor Oil Saver is an ester-based additive. It will thicken up the oil slightly, but nothing major.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#3353150 - 04/25/14 05:52 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
Yannick Offline
10-4 Boss !!!
#3353158 - 04/25/14 05:59 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
147_Grain Offline
Loc: USA
A VOA of Lubro Moly a few years ago showed viscosity characteristics similar to a 5W-30.
Here's an example from 2008 VOA:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1234989
#3353169 - 04/25/14 06:12 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: 147_Grain]
dailydriver Offline
Loc: Bucks County, Pa.
We are talking about the Motor Oil saver in this thread, NOT the MOS2.
The Motor Oil Saver IS one of the most viscous additives I've ever seen anywhere (even more so than the old VSOT stuff), but, as has been stated, adding 300ml of it to 5+ quarts of oil will not do much to change the HTHSV, nor the cSt @100*C. wink
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3353186 - 04/25/14 06:26 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
147_Grain Offline
Loc: USA
Oops! frown
#3353312 - 04/25/14 08:33 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
Yannick Offline
got it !
#3354271 - 04/26/14 10:33 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: dailydriver]
HTSS_TR Offline
Loc: Lake Forest, CA
What I observed is different with yours, VSOT is much thicker than Lubro Moly Oil Saver.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3354791 - 04/27/14 04:08 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: HTSS_TR]
dailydriver Offline
You are probably correct on this as I have not handled the VSOT product in MANY years now, and have forgotten just how 'frozen molasses-like' that stuff was. wink LOL
M1-206 oil filter
