New Bridgestone run flat
Keeps You Moving for 50 Miles
DriveGuard tires are specifically engineered to be able to take a puncture and keep you moving. Their supportive and tough reinforced sidewalls help ensure your mobility for up to 50 miles at a maximum speed of 50 mph.
Stays Cool Under Pressure
Thanks to our proprietary patented high-tech cooling fin design and reinforced sidewall rubber, DriveGuard tires redistribute heat and friction after a puncture, you can keep driving for up to 50 miles, even after complete air loss
Delivers a Quiet, Comfortable Ride
With DriveGuard, there’s no need to sacrifice ride comfort for peace of mind. Lightweight construction and a unique all-season tread pattern work together to provide ride comfort, confident wet traction, and responsive steering control.
Notifies Your Car's TPMS
DriveGuard tires are designed for vehicles equipped with a Tire Pressure Monitoring System (TPMS). So when the indicator on your dashboard lights up, you know you’ve got 50 miles to drive to safety.
Protection When It Counts
Every DriveGuard tire comes complete with the DriveGuard Protection Package – one of the most comprehensive warranty packages in the business – so you know you’re choosing a tire that has you covered when it matters most.
