- Joined
- Dec 7, 2012
- Messages
- 3,558
I have an Accord LX which doesn't come with factory wiring connectors for fog lights. There are kits on eBay (aftermarket) that you can install, but the wiring harness IMO is cheesy, so is the switch. I went ahead and ordered the kit (basically wanted the light housings), an HID harness from LightWerkz, some H11 connectors and a Honda OEM switch out of a Honda Fit and made my own high quality harness. I soldered and heat shrunk, and then taped over and used wire loom! I "loosely" hooked up the wires just to make sure the harness works and it worked flawlessly. The system is now unhooked as I'm taking my time to run the wiring neat, securing it properly and following most if not all OEM wiring locations. I am not a hack and HATE HATE HATE hack work.
Overall I'm so happy with this. I'm no electrical engineer, but proud of myself for being able to figure out relays and wiring... used a multimeter and test light quite a few times. If anyone wants any more info, just ask.
They're in!
My Wiring Diagram
It works! It's ALIVE!
The closest I'll come to being a hack, just a test!
The Switch.
They're in!
My Wiring Diagram
The Switch.
