I bought this last August with almost 27000 on the clock. It was a daily rental and I bought it at the Dodge dealer where my son is apprenticing so the guys in the shop went over it pretty good. They use Pennzoil products and it had a fresh fill of PYB and a Mopar filter when I picked it up. I ran that about 6000km and changed it in November because I don't know how long the OLM goes and I was planning on a spring/fall schedule.
I don't know what the future schedule will be as I recently have gone back to solo commuting, car pooler has moved. I will likely just let this fill run out the oil change indicator. If that happens to be in the cold weather, I think I'll just give the oil to my son and get him to do it at the shop, I'm done crawling around in the snow unless I have to. With the increased mileage it's going to see that may not be the case though.
FILTER
- Mopar MO-744
USAGE
- About 60% highway
NOTES
- Cold winter, plugged it in several times this year
- Oil pressure at 1200RPM never really changed at all over the OCI (35 PSI)
- Analysis done by Toromont/Caterpilar
Code:
DATE: 04/13
OIL: Pennzoil
Platinum
5w20
FILTER: MO-744
TOTAL KM: 42798
KM ON OIL: 7857
TOP UP: 0
Fe: 14
Cr: 1
Mo: 53
Al: 3
Cu: 20
Pb: 0
Sn: 0
Ti: 0
Ni: 0
Ag: 0
Si: 10
Na: 6
K: 1
Zn: 874
Mg: 12
P: 757
Ba: 0
B: 13
Ca: 2333
Mn: 1
V: 0
SOOT: 0
SULF: 24
OXID: 17
NITR: 13
VIS CST: 8.43
TBN: 5
COOLANT: NEG
FUEL: NEG
WATER: NEG
FILTER
- Mopar MO-744
USAGE
- About 60% highway
NOTES
Code:
DATE: 04/13
OIL: Pennzoil
Platinum
5w20
FILTER: MO-744
TOTAL KM: 42798
KM ON OIL: 7857
TOP UP: 0
Fe: 14
Cr: 1
Mo: 53
Al: 3
Cu: 20
Pb: 0
Sn: 0
Ti: 0
Ni: 0
Ag: 0
Si: 10
Na: 6
K: 1
Zn: 874
Mg: 12
P: 757
Ba: 0
B: 13
Ca: 2333
Mn: 1
V: 0
SOOT: 0
SULF: 24
OXID: 17
NITR: 13
VIS CST: 8.43
TBN: 5
COOLANT: NEG
FUEL: NEG
WATER: NEG
