Originally Posted By: edyvw
Originally Posted By: rhhsiao
Run the oil longer unless you're constrained by the manufacturer recommended OCI.
This is Low-SAPS. 2.0T are hard on oil, even some High-SAPS cannot retain TBN properly. My 5K OCi on M1, TBN was at 2.6.
I was replying to the OP. Sure the oil is Low-SAPS, but even if the engine is "hard on oil", where does that show up in the UOA on this run? Why is a TBN of 2.6, in your case, unacceptable? TBN for the OP is 4.3 and wear metals are all within average ranges. If his TBN was also 2.6 and wear metals didn't budge, would you automatically assume the oil is now unfit for use?
