Originally Posted By: CapriRacer
I do wonder how the use of winter tires has impacted things. It wasn't that long ago that the use of winter tires wasn't really that common. Things have changed over time.
For me, swapping summer/winter tires is the only time I rotate as we only do a maximum of 10k on either. Just put the 2 with most tread on the front each time.
I imagine for those who run the same tires year round, the use of quick lube places has removed any easy opportunity to rotate tires as they all use a pit. Those going to a real mechanic for oil changes probably do get their tires rotated more often as the car is usually on the lift regularly.
