Hello all..first post here!
1997 Honda Civic EX
1.6L VTEC
162,000 miles
Southern Maryland
Mostly highway driving and I push it pretty hard most of the time
I’m looking for an opinion on my current oil and OCI’s. I have always been told to run a full synthetic then switch to high mileage around 80K with OCI’s around 3K. After doing some research I see that’s not always the case. Bought the car used from the original owner but I’m pretty sure they never ran synthetic in it. Car runs great, just did the full tune-up on it but it does have an oil leak from what I believe is either the pan gasket or from what Honda tells me is the front and rear main seal (how they were able to tell from all the oil everywhere ill never know). It’s not a bad leak but definitely leaves spots in the driveway and I have to add half quart or so around 2,500 miles or so between oil changes.
I guess my question is, should I stick to a good high mileage and what is your opinion on the best of that or would synthetic be better?
Would either help the oil leak or is there something I can add to help or aide for now?
5W-30 is what it calls for but would anything work better in my situation?
Always used either the M1 filter or Purolator filters?
3K OCI’s too short or do you think I could stretch to 5K?
I always used Pennzoil Ultra in my truck before I sold it but I have been using Pennzoil High Mileage 5W-30 in the car with the Restore 4 cylinder additive. I got a good deal on some M1 High Mileage and M1 filter so that’s what I’m going to put in her in a few weeks. I live in Maryland where the summers are hit or miss as far as high temps go but it’s never too too bad.
Thank you all very much for the help…need to make her last a few more years before I invest in that NEW truck!
1997 Honda Civic EX
1.6L VTEC
162,000 miles
Southern Maryland
