Hello all,
I will be doing the brakes on a 2000 RWD Chevy astro. I was curious about a few things.
-What size is the nut that holds the rotor/bearing assembly on? I can't find this info online.. it doesn't appear to be on tight maybe a simple monkey wrench will work.
-What size is the Allen bolt that holds the caliper on, I have seen people say multiple things, 10mm, 9mm, and 3/8. Not sure which one exactly.. most people seem to say 3/8.
-I will be replacing both the inner and outer bearings with new ones since they are relitively cheap anyways, any tips on installing them, and what is a good bearing grease to use?
Thanks all!
Thanks all!
